Removing Driver Lower Dash ??
dazz
Drives: Polo 6R Comfort Line 2010
Post by dazz »
Hi
Is it possible to remove the lower dash trim below (but not on) the steering wheel.
It looks like it should separate from the dash but I think I can see some glue.
I want to get access to the BCM / relay panel to do some fault finding on my wiper delay.
The wiper delay doesn't work on any of the 4 positions. I need to figure out if it is the BCM or the wiper switch that is the problem.
peter_dk25
Drives: Blue GT
Re: Removing Driver Lower Dash ??
Post by peter_dk25 »
No it is a part of the Dash - so it is the hard way: Down on your back with a lamp in your mouth. Not easy but it can be done :-)
