Knock sensor replacement 2012 polo help please?
Wizzi07
Drives: 2012 polo
Post by Wizzi07 »
Hi I have a 2012 polo 1.4 and it has a faulty knock sensor.
Could somebody please tell me where abouts the sensor is and how to get to it
Thanks!
MichelKasapovic
Drives: Polo 1,2 tsi 90bhp 6r,6c
Re: Knock sensor replacement 2012 polo help please?
Post by MichelKasapovic »
Is it a tsi motor?
If it is the 1.4 16v 85PS engine, are you sure that it has a knock sensor - I'd doubt it! If you are experiencing pinking on load, then I'd think that it will be due to the car burning engine oil due to wear on the bores/rings - or the oil separator is faulty, that happened to me with a 2000 BBY version of that engine. Initially I tried using UL+ petrol, that worked okay but increased fuel usage and running costs.
Wizzi07
Drives: 2012 polo
Post by Wizzi07 »
It's not a tsi engine.. I did a diagnostics reading with vcdS and it came back with knock sensor low voltage fault
Wizzi07
Drives: 2012 polo
Post by Wizzi07 »
The fault is 16711 knock sensor (g61) p0327 -000- signal too low. Mil on
Oh well it might have one, I have been caught out with VW's rubbish engine software in the past, wife's old 2002 Polo used to log Bank2 camshaft timing issues, these 4 in line engines just don't have a second cylinder bank!
