Reverse Mirror Tilt 6C GTI
Monty246810
Drives: 2015 polo gti
Post by Monty246810 »
Hello everyone can anyone help I want to code the Reverse Mirror Tilt on my 2015 Polo GTI 2015 model. Is there some one that can give me the process on how to do this thanks to who ever can help. My car has Mirror Fold fitted as this seems to be a question that I have been asked so that this can be done.
Re: Reverse Mirror Tilt 6C GTI
can't be done, sorry
Adam87
Drives: T5.2
Post by Adam87 »
iichel wrote:can't be done, sorry
What is it preventing this? I know the door mirror will need a different type of motor with extra wires, but is it the door module that doesn't support it?
it simply doesn't have the software to do this
Take a look to Elsawin, VW FOX 2013 (D) ---> J351 :twisted:
Adam87
Drives: T5.2
Post by Adam87 »
Good find [emoji106] do you know what modules the fox uses? Are they TSG like polo Transporter?
Adam87 wrote:Good find [emoji106] do you know what modules the fox uses? Are they TSG like polo Transporter?
NO.
Crossfox 2017 (without serial numbers or VCID)
Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 089 HW: 7E0 937 089
Component: BCM PQ25 MMI4 H80 0733
Revision: BB080001 Serial number:
Coding: 3A8CCBB84C3BC600103A06C07E88BA80B000629C60842000240580020000
Shop #:
VCID:
Subsystem 1 - Part No SW: 5Z0 959 800 B HW: 5Z0 959 800 B
Component: ZFH_Cross H08 0015
Serial number:
Coding: 006B54
Subsystem 2 - Part No SW: 5Z0 959 800 B HW: 5Z0 959 800 B
Serial number:
Coding: 006B54
Subsystem 3 - Part No: 5Z0 947 105 F
Component: DWA-Sensor 00 003 0008
Subsystem 4 - Part No SW: 18D 959 442 HW: 18D 959 442
Component: E221__MFL-YLG H01 0110
Serial number:
Coding: 200000
Subsystem 5 - Part No SW: 5Z0 959 800 B HW: 5Z0 959 800 B
Serial number:
Coding: 006B54
Subsystem 6 - Part No SW: 5Z0 959 800 B HW: 5Z0 959 800 B
Serial number:
Coding: 006B54
Address 46: Central Conv. Labels: None :shock: :lol:
Part No: 5Z0 959 800 B
Component: Z F H GOL/FOX H08 0015
Coding: 0000001
Shop #: WSC 00000 000 00000
VCID:
Adam87
Drives: T5.2
Post by Adam87 »
Maybe the mirrors are controlled by the convenience module? I wonder if it can be fitted but only used for certain functions? I.e. Convenience menu, mirror dip
I think they are not the same units for convenience menu and lowering mirror. The lowering mirror unit is from a 2013 model.
Both units would have to cross the Atlantic Imageto do the tests and check if they fit ... via coding of the required functions/features. :wink:
I do not have the diagrams from 2017 model (despite I visited Erwin recently due to other matters)
Adam87
Drives: T5.2
Post by Adam87 »
I checked and it seems there is a dedicated control module for the lowering (J1110) all mirror switch wiring goes through it, pq35 platform cars have it working via the door module, what can't it be that easy [emoji85][emoji23]
C_Randell_23
Drives: 6C GTI Black 3dr Manual with toys
Post by C_Randell_23 »
Do what I do, save loads of hassle and just manually lower the mirror every time it comes to parallel parking, takes an extra 10 seconds to tilt it but that s better than £80 for a wheel refurb.
Adam87
Drives: T5.2
Post by Adam87 »
Ball ache that tho [emoji23]
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
This is not working with 7E0?
Adam87
Drives: T5.2
Post by Adam87 »
Additionally if the BCM could control it, you need passenger mirror with additional potentiometers in to carry out the mirror dip
