Rear window help?!
Rear window help?!
can anyone tell me iff the rear window glass is the same between the sallon and the coupe/hatch?? need to take my rear window out, don't want it to break but if it does will any of the others fit??
craig
craig
Tahrey1043
- Location: Birmingham! Enjoys: The pseudo-G-Smiles provided by a 1.6 Megane Sport valver...
GroovyCarrot
- Sponsor
GroovyCarrot
- Sponsor
- bstardchild
- Moderator
Whydubs wrote:Hmmmm ok, does anyone know if the rear window rubbers are still available to buy?? looks like the only option is to cut the rubber!!!!!!
really dont want to but dont have much choice
I haven't got a polo MKII any more but was sure that the window rubber wasn't glued in but a flexible rubber wrapped all round the glass - rolled over the lip/mount in the tail gate.......
If this is the case then starting from the inside of the tailgate roll the inside of the rubber of the lip (have someone holding the window glass to stop it falling out) and work your way all round from the top down both sides - should just pop out of the bottom.
To get it back in rest it in the bottom lip and with a bit of string wrapped all the way round inside the seal pull it back into the seat.....
Of course if it is bonded in I'm talking rubbish but I'm sure it isn't
If you are unhappy about trying to do it yourself - go to a branch of autoglass and see if they'll take it out for a donation to the tea fund
i have a habit of breaking windows when removing thembstardchild wrote:Whydubs wrote:Hmmmm ok, does anyone know if the rear window rubbers are still available to buy?? looks like the only option is to cut the rubber!!!!!!
really dont want to but dont have much choice![]()
- bstardchild
- Moderator
In that case don't try and push it out till the seal is rolled off all the way round both sides and the top - bottom bit doesn't matter as you can lift it up.....dubs wrote:i have a habit of breaking windows when removing themyeah its the rubber seal type not bonded.
I've done several windows with rubber seals before and never broken one yet - just take it slow - don't try and hurry it - plastic (flexible - the unbreakable type) rulers help a lot cos you can use that to run along the rubber seal once you've started to roll it over and it makes quick work of it
Tahrey1043
My window problems are now saved, sat in the scrappy with a mate getting bits for hiw vento and what gets trailered in?!?!?!?!?!?!?!?!?
a mk3 polo saloon, quick peek reveales the rear window and rubber are immaculate
plus the panels seems quiet good aswell, looks like i have me a donor to strip and pinch bits off, and its the same colour!! BARGIN
