Check coolant polo gti
rm55mcc
Drives: Polo 1.4
Post by rm55mcc »
Started the car today , check coolant light came on, opened the bonnet , coolant tank empty and coolant all over the engine bay! Has any one had this??
Re: Check coolant polo gti
It could be anything really, needs investigating and correcting before you next drive it or you could cause more damage.
I'm guessing a leak?
joe6
Drives: Golf Mk6 GTI (Scirocco gone) Polo 6c GTI
Post by joe6 »
If you have coolant over the engine bay then the first thing to do is hose it off as it wrecks paintwork. Check the coolant filler cap is tight as this can leak under pressure when hot. Next check hoses for leaks - need to top up first and warm the engine to try to identify any joint leaks and then hose leaks. Garages put in a special dye to help identify where the leaks are. VW have had coolant pump leakage problems in the past and some garages suggest changing the pump when doing a timing belt change.
rm55mcc
Drives: Polo 1.4
Post by rm55mcc »
Ok so turns out the pipes behind the fan have worn through and spraying coolant all over the engine bay..
You can see we're is worn through on the photo and spary off coolant..
Penarth Blues
Drives: 2015 Polo GTI 5 door Black M6
Post by Penarth Blues »
rm55mcc wrote:Ok so turns out the pipes behind the fan have worn through and spraying coolant all over the engine bay..
That's worrying... What were they rubbing on, and how many miles have you got on the car?
rm55mcc
Drives: Polo 1.4
Post by rm55mcc »
The fans.. 8k on the car
Penarth Blues
Have you informed the garage? Sounds like something's been left off the car in terms of hose management...
rm55mcc
Drives: Polo 1.4
Post by rm55mcc »
Yeah it's been recovered next week and get sorted [emoji106]
Penarth Blues
rm55mcc wrote:Yeah it's been recovered next week and get sorted [emoji106]
What did the garage say had caused the fouling of the water hose in the end?
rm55mcc
Drives: Polo 1.4
Post by rm55mcc »
Nothing as my car still in my garage , part still hasn't came in yet , so as soon as it does there sending someone to my house to fix it [emoji106] busting to get driving it again , been 3 weeks now [emoji37]
rm55mcc
Drives: Polo 1.4
Post by rm55mcc »
So the Gti is now fixed , the new pipe that was put on is slightly different and sits back from the fans now so shouldn't split this time , it's a revised pipe so this issue doesn't occur again.. [emoji106][emoji106]
Penarth Blues
rm55mcc wrote:So the Gti is now fixed , the new pipe that was put on is slightly different and sits back from the fans now so shouldn't split this time , it's a revised pipe so this issue doesn't occur again.. [emoji106][emoji106]
Cheers for that - implies this could be an issue for all early GTi's... I need to go and check mine...
rm55mcc
Drives: Polo 1.4
Post by rm55mcc »
I'll take a pic off new pipe tomorrow and you will be able to see it sits back from the fans [emoji106]
Penarth Blues
That'd be really helpful - thank you :)
