Check coolant polo gti
Started the car today , check coolant light came on, opened the bonnet , coolant tank empty and coolant all over the engine bay! Has any one had this??
Re: Check coolant polo gti
It could be anything really, needs investigating and correcting before you next drive it or you could cause more damage.
I'm guessing a leak?
joe6
If you have coolant over the engine bay then the first thing to do is hose it off as it wrecks paintwork. Check the coolant filler cap is tight as this can leak under pressure when hot. Next check hoses for leaks - need to top up first and warm the engine to try to identify any joint leaks and then hose leaks. Garages put in a special dye to help identify where the leaks are. VW have had coolant pump leakage problems in the past and some garages suggest changing the pump when doing a timing belt change.
Ok so turns out the pipes behind the fan have worn through and spraying coolant all over the engine bay..
You can see we're is worn through on the photo and spary off coolant..
Penarth Blues
- Drives: 2015 Polo GTI 5 door Black M6
That's worrying... What were they rubbing on, and how many miles have you got on the car?rm55mcc wrote:Ok so turns out the pipes behind the fan have worn through and spraying coolant all over the engine bay..
Penarth Blues wrote:That's worrying... What were they rubbing on, and how many miles have you got on the car?rm55mcc wrote:Ok so turns out the pipes behind the fan have worn through and spraying coolant all over the engine bay..
The fans.. 8k on the car
Penarth Blues
Have you informed the garage? Sounds like something's been left off the car in terms of hose management...rm55mcc wrote:Penarth Blues wrote:That's worrying... What were they rubbing on, and how many miles have you got on the car?rm55mcc wrote:Ok so turns out the pipes behind the fan have worn through and spraying coolant all over the engine bay..
Yeah it's been recovered next week and get sorted [emoji106]
Penarth Blues
What did the garage say had caused the fouling of the water hose in the end?rm55mcc wrote:Yeah it's been recovered next week and get sorted [emoji106]
Penarth Blues wrote:What did the garage say had caused the fouling of the water hose in the end?rm55mcc wrote:Yeah it's been recovered next week and get sorted [emoji106]
Nothing as my car still in my garage , part still hasn't came in yet , so as soon as it does there sending someone to my house to fix it [emoji106] busting to get driving it again , been 3 weeks now [emoji37]
So the Gti is now fixed , the new pipe that was put on is slightly different and sits back from the fans now so shouldn't split this time , it's a revised pipe so this issue doesn't occur again.. [emoji106][emoji106]
Penarth Blues
Cheers for that - implies this could be an issue for all early GTi's... I need to go and check mine...rm55mcc wrote:So the Gti is now fixed , the new pipe that was put on is slightly different and sits back from the fans now so shouldn't split this time , it's a revised pipe so this issue doesn't occur again.. [emoji106][emoji106]
Penarth Blues wrote:Cheers for that - implies this could be an issue for all early GTi's... I need to go and check mine...rm55mcc wrote:So the Gti is now fixed , the new pipe that was put on is slightly different and sits back from the fans now so shouldn't split this time , it's a revised pipe so this issue doesn't occur again.. [emoji106][emoji106]
I'll take a pic off new pipe tomorrow and you will be able to see it sits back from the fans [emoji106]
Penarth Blues
That'd be really helpful - thank yourm55mcc wrote:Penarth Blues wrote:Cheers for that - implies this could be an issue for all early GTi's... I need to go and check mine...rm55mcc wrote:So the Gti is now fixed , the new pipe that was put on is slightly different and sits back from the fans now so shouldn't split this time , it's a revised pipe so this issue doesn't occur again.. [emoji106][emoji106]
