I'm Sorry ciclo. I meant the same result for the high beam problem. thank you too for the Codingciclo wrote: Tue Jan 30, 2018 5:12 amIMPOSSIBLEfedericodrdpro wrote: Mon Jan 29, 2018 10:00 pm EDIT:
.. I have the same results of iichel coding and appear the lights check on the tacho.
Good luck!!!
Bye.
The wiring is:iichel wrote: Tue Jan 30, 2018 8:22 am ..
just to verify, the high beams are still via the high beam stalk and the fuse box SB34 15A, and both high beams work, and the fuse is intact?
from T73a/62 to exSB34 (white/green original wire)
from exSB34 (white/green original wire) to SB34 terminal
Yes the SB34 fuse is intact.
EDIT:
When the engine is ON the high beam seem to work well.
