[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 mrk 4 side repeaters - UK-POLOS.NET - THE VW Polo Forum
I've just bought some clear side repeaters for my 96 polo and can't see anyway of getting to the side repeaters to actually remove them. How can i remove them to fit my new ones?
jules_cm wrote:I've just bought some clear side repeaters for my 96 polo and can't see anyway of getting to the side repeaters to actually remove them. How can i remove them to fit my new ones?
Can't remember if it's slide em forward and they pop out at one end or slide em back and they pop out - basically it's easy look at your new ones and you'll see one end is a fixed lug and the other end is sprung plastic - you have to compress the sprung plastic end to enable the lug end to pop out
i think its push towards the back end of the car. its only a 5 min job. wiggle bout with the old 1 to get away from the front wing and then pull (quite tight) the connector.
david burton wrote:depends which way they were put in in the first place
Thats why I was hesitant in pointing out the direction to push or pull - I'm sure one side of mine it was push to the rear the other side it was push to the front....
