I have some questions about Instrument Cluster.
My polo is a 1.2 TDI Bluemotion, so:
My VCDS detect always the same fault on module 17-Instrument; it says:
Part No SW: 6R0 920 861 F HW: 6R0 920 861 F
Component: KOMBI H04 0304
Coding: 540800
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
VCID: 3878F3A283C8CB8111-806C
1 Fault Found:
10485833 - Internal Control Module Memory Check Sum Error
B2000 49 [137] - Internal electronic failure
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 76526 km
Date: 2014.02.22
Time: 17:34:38I searched on the web but I can't find a solution. I think that the only solution is to replace the instrument cluster.
1) Can you guys help me if possible to solve this fault??
2) If the only way is to replace the Intrument Cluster, can I put a 6c, or a 6R GTI intsrument?
3) My code of that part is: 6R0 920 861 F; if I found another part with different code (e.g.:6R0 920 861 H), I need to recode Instrument??
Sorry for my bad english, anyway thanks to all!
