BCM Max PQ25, adaptation. Automatic lights. Skoda Citigo/VW Up!
Re: BCM Max PQ25, adaptation. Automatic lights. Skoda Citigo/VW Up!
Hi Daniel. Good job!danikd wrote: Sun Dec 02, 2018 8:57 pm Ciclo, finally did it, fogs, DLR cables, new battery, new headlights, new BCM ... many thanks, working great. You are pro!
5 questions ...
1.
Pls see log - there is lic. plate error - have LED, so can be the bulb check uncoded? I find some :
check Bit 7 of Byte 17 and uncheck k Bit 6 of Byte 23 ... or any way?
Or resistor must be used? Bulb is working of course ...
2.
Module 61 battery regulator - its shows error in VCDS - see log. Only in module list, in detailed scan not ...My Citigo dont have bat. regulator - any way to disable it in BCM ( its part of BCM? )? Or coded to clear error permanently?
3.
Strange module 0B - Sec. Air Heating - showsa only in VCDS module screen, in scan not ... What its ???
4.
Gateway i recoded to 002000 - as was my old BCM Gateway ... Its OK?
5.
Its possible to install Auto Hadlight Assistent? Auto high beam? BCM support it ( right?), so need new stalks, camera ... how to check that instruments are compactible?
Many thanks for your great work master, nice day to Spain!
Daniel
Sunday,02,December,2018,17:52:44:61091 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 18.2.1.2 Data version: 20180518 DS287.1 www.Ross-Tech.com Dealer/Shop Name: DD Workshop Code: 123 12345 012345 VIN: TMBZZZAAZDD615614 License Plate: Mileage: 52230km-32454mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: AA-VW12 (7E0) Scan: 01 03 04 09 10 15 17 19 25 44 56 AD VIN: TMBZZZAAZDD615614 Mileage: 52230km-32454miles 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 56-Radio -- Status: OK 0000 61-Battery Regul. -- Status: Malfunction 0010 AD-Brake Sensors -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CHYA) Labels:. 04C-906-020-CHY.clb Part No SW: 04C 906 020 K HW: 04C 907 309 D Component: 1.0l R3 MPI H01 6470 Revision: U7H01--- Serial number: Coding: 00110012022400000000 Shop #: WSC 12345 123 12345 ASAM Dataset: EV_ECM10MPI01104C906020K 001010 ROD: EV_ECM10MPI01104C906020.rod VCID: 23E9EB59C0953D86C0-8076 No fault code found. Readiness: 1110 0101 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 1S0-614-517.clb Part No SW: 1S0 614 517 L HW: 1S0 614 517 F Component: EBC 460 ESP H16 0023 Serial number: A00QBIZ Coding: 32BF247129AE02F64C0024F694AD40405FB100 Shop #: WSC 12345 123 12345 ASAM Dataset: EV_Brake1ESPEBC460TRW 002004 ROD: EV_Brake1ESPEBC460TRW_002_VW25.rod VCID: 3802C518340ABF13A8-806C No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb Part No SW: 7E0 937 090 C HW: 7E0 937 090 C Component: BCM PQ25 Max4 H82 0752 Revision: B9082001 Serial number: 4000 228170707 Coding: 6CB82B0000010000010800647CEB86E073C0626D608F30E1200000460000 Shop #: WSC 12345 123 12345 VCID: 2BF1DB21E84D6DBE00-807E Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB Component: RLS 121016 04 42 0106 Coding: 0728DD Subsystem 2 - Part No SW: 5E0 919 719 L HW: 5E0 919 719 L Component: E221__MFL-PR6 H02 0160 Serial number: 000000000B0452131116 Coding: 820000 1 Fault Found: 01504 - Bulb for License-Plate Light (X) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 63 Mileage: 52236 km Time Indication: 0 Date: 2018.12.02 Time: 00:16:53 ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels:| 1Sx-919-475.clb Part No SW: 1ST 919 475 HW: 1Q0 919 475 Component: PARKHILFE 3K H03 0005 Revision: -------- Serial number: 32901224704087 Coding: 100001 Shop #: WSC 31414 790 00001 ASAM Dataset: EV_EPHVA14SK1200000 001001 ROD: EV_EPHVA14SK1200000.rod VCID: 1BE1FB71A0BDCDCE80-804E No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 5K0-959-655.clb Part No SW: 1S0 959 655 HW: 1S0 959 655 Component: VW10Airbag00E H03 0005 Revision: -------- Serial number: 003G3004KBR+ Coding: 000000000000000000000000000000003045 Shop #: WSC 31414 790 00001 ASAM Dataset: EV_AirbaVW10BPAVW12X 001001 ROD: EV_AirbaVW10BPAVN750_VW12.rod VCID: 7B413B5120DD0D6E80-802E Crash sensor for side airbag: driver side: Serial number: 3495RRB40591GLOMAGHG Crash sensor for side airbag: front passenger side: Serial number: 3505RRB405J1GLOOE0C3 Crash sensor for front airbag: driver side: Serial number: 3555NRB405R1HA3O6P8. No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 1Sx-920-xxx-17.clb-SRI1 Part No SW: 1ST 920 870 A HW: 1ST 920 870 A Component: KOMBI H05 0008 Revision: X0005001 Serial number: 00000000000000 Coding: 114A010000 Shop #: WSC 31414 790 00001 ASAM Dataset: EV_KombiUDSMM9RM10 A05808 ROD: EV_KombiUDSMM9RM10_A05_VW12.rod VCID: 53198BA980851D5640-8006 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb Part No SW: 7E0 909 901 HW: 7E0 937 090 C Component: GW-K-CAN TP20 H82 0752 Revision: B9082001 Coding: 002000 Shop #: WSC 12345 123 12345 VCID: 68326568FC3A9FE328-803C No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb Part No SW: 5K0 953 234 HW: 1ST 920 870 A Component: IMMO H05 0008 Revision: X0005001 Serial number: 00000000000000 Coding: 000000 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_ImmoUDSMM9RM10 A01702 ROD: EV_ImmoUDSMM9RM10_VW12.rod VCID: 6A305966EC30EBF538-803E No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist (J792) Labels:| 1Sx-909-144-44.clb Part No SW: 1S1 909 144 G HW: 1S1 909 144 G Component: EPS_ECU H30 1503 Coding: 0001000101000000 Shop #: WSC 31414 790 00001 ASAM Dataset: EV_SteerAssisNSK 009004 ROD: EV_SteerAssisNSK_009.rod VCID: 3705C31D3031B50AA0-8062 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb Part No SW: 1ST 035 156 A HW: 1ST 035 156 A Component: Radio H35 0051 Revision: R0000000 Serial number: SKZAZ1M3007678 Coding: 0000020801 Shop #: WSC 00070 000 00000 VCID: 4D1F9FDF90A339A010-8018 No fault code found. ------------------------------------------------------------------------------- Address AD: Brake Sensors (J939) Labels: 1S0-907-201.clb Part No SW: 1S0 907 201 A HW: 1S0 907 201 A Component: CV-SENSOR H08 0460 ASAM Dataset: EV_CVSen 001001 ROD: EV_CVSen.rod VCID: 28F2E528F47A1FA328-807C No fault code found. End-------------------------(Elapsed Time: 02:24)--------------------------
1
To solve the problem of LED license plate lights in your Citigo.
First thing, try this new BCM coding:
6CB82B0000010000010800647CEB86E073C0626D608F30E1200000470000
This way you'll also have the diagnosis of LED license plate lights.
If the previous coding in your Citigo and LED license plate lights (OEM or not OEM?) doesn't work, enter this new BCM coding:
6CB82B0000010000010800E47CEB86E073C0626D608F30E1200000470000
Report the result ...
2
Explanations:
It seems that your new BCM MAX comes from a vehicle with Start/Stop (bluemotion), i.e, with Address 61.
Do the following:
- Enable address 61 in Gateway installation list.
- Go to address 61 and code all Bytes to 00.
- Return to GW installation list and disable the address 61.
- Go to Autoscan and Click on Gateway installation list button.
- Click on Clear All DTCs.
The address 61 should no longer be present in the Autoscan.
Report the results...
3
It's related to your VCDS cable model...
4
It's perfect, as it should be.
5
To know if your Citigo's instrument cluster would support HBA, there is only one way to find out.
- Enter in BCM adaptation, go to channel 53, new value 1 (from 0 to 1), save.
- Push the HB stalk, the A simbol should appear in the IC screen.
When you finish this check, return to value 0 on channel 53.
If it works, take a big picture and show it here ...
Hi!
1
First coding help, no more X Bulb error ... Great!
2
It helps, no more 61 module ... Great!
3
OK, have some clone ... Not so great
4
Thx ... Great!
5
BCM Adaptaion chanel 53 test - No A icon on MFA
I dont have HBA compactible stalks with spring forward position - I have 6Q0953503EJ ... Can the test been done with normal stalks?
And somewhere in yours Polo thread I saw something about channel 54 ...
Thx info Polo.Master
1
2
3
4
Thx ... Great!
5
One more question ... more important ... seem that DLR LED are not on full brightness ... Any way to check it or change it? Many thynks. Daniel
Ciclo, pls, what is byte 16 - bit 2 - daytime running lights via pwm active ? Many thx for expalnation ... Dan
yesdanikd wrote: Tue Dec 04, 2018 9:29 pm Ciclo, pls, what is byte 16 - bit 2 - daytime running lights via pwm active ? Many thx for expalnation ... Dan
'Seems' is a very relative term.danikd wrote: Tue Dec 04, 2018 12:28 pm One more question ... more important ... seem that DLR LED are not on full brightness ... Any way to check it or change it? Many thynks. Daniel
Remember that I don't know how the Skoda Citigo particularities are.
Edit:
Oh yes, I forgot to comment that enjoy all the new features in your Skoda Cítigo.
...I'm afraid that the HBA will not be possible in your Citigo. (due to your IC)
Hello, thx, so I have to activate this bite? Its unticked ...
I will compare my lights with another Citigo ... maybe is normal ...
But expected little more light
Daniel
Test, there's no problem.
If you don't achieve your goal, return to the previous state.
After pluging 20 pins to Citigo/Up! BCM, there is no way back ... there is about 1/3 of space than in your Polos
Next week heated windshield from e-up!
Many thx. Daniel
I was referring to Byte16 Bit2, I was not referring to return the whole installation to previous state...
Good luck with the new heated windscreen!
.. take a picture and show us here your new DRLs... please...
danikd wrote: Thu Dec 06, 2018 9:15 pm Seem sto be OK, man have to look at DLR from little distance ...
DLR seems to be OK ...
Main reason was light output - old H1 headlights - only low or beam was working ... New 2xH7 - both bulbs are lightning in highbeam, so its much better ... And they looks better ...
Wow! It's really beautiful.
Thanks for the picture.
Which AUTO light switch did you finally install?
To compare:
To compare:
Exact one you recomend, but I plan to white -red ilumination, I will buy the one you have in your Polo ... D
1Z0941431K
viewtopic.php?f=56&t=71456#p535870
Well, I think that with green backlighting is fine for your Citigo (especially for your nice green Citigo)
This is the one I have https://imgur.com/IQ1fa8a installed in my 6R, but currently it is difficult or impossible to find.
