Polo 6R - Useful Part Numbers
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
thanks CNK :)
CNK
Drives: 6R
Post by CNK »
ag69 wrote: Thu Jun 06, 2019 7:35 amthanks CNK :)
no problem
A & B should be cheaper, because are older, without AndroidAuto/CarPlay support.
C = 2 USB sockets
D = 3 USB sockets
HSD LVDS wires (e.g. 5Q0035320A from Golf VII) aren't cheap, but you can buy them from aliexpress or local shops.
Female :arrow: Female :wink:
ed.silmon-monerri
Drives: 6c 1.4 TDI SE
Post by ed.silmon-monerri »
2014-2015 (on to 2018?) Polo 6c Manual Air-conditioning vent-flap air temperature sensor 6Q0907543F ~£30 from VW Access on RHD for a thinly armed person is 2/3rds of an arms length up between clutch and brake pedal, pointing horizontally left into airbox, needs about 1/2 turn to loosen then it sorta slides out. Connector needs two tiny tabs pinched inward to release. Very few of them around... Image
Is that the evaporator temperature sensor, used to control the flow of liquid/gas into the evaporator to prevent it from getting down too low in temperature and ending up freezing all the moisture on its face and so blocking the air passing through a bit or a lot?
ag69
Post by ag69 »
does anyone using 5GV-051-629-J on VW Polo 6R?
Though this could/should be universal component, compatibility list shows Polo but not Polo 6R.
https://shops.volkswagen.com/de_DE/web/ ... 051629j-10
CNK
Drives: 6R
Post by CNK »
Unfortunately it doesn't work with 6R
ag69
Post by ag69 »
thanks cnk
surprisingly vw India mentions/sells this for VW Polo/Vento variants which are 6R based
https://www.volkswagen.co.in/en/accessories/polo.html
there is a section "Volkswagen Connect" and this is listed.
CNK
Drives: 6R
Post by CNK »
maybe this Ameo 6RG has different BCM or something, I don't know. In Poland it's not possible to order it to 6R hatchback
smg_shardul
Drives: Polo 6R
Post by smg_shardul »
ag69 wrote: Fri Aug 23, 2019 7:14 am does anyone using 5GV-051-629-J on VW Polo 6R?
You can use to polo 6R
smg_shardul
Drives: Polo 6R
CNK wrote: Fri Aug 23, 2019 1:17 pm maybe this Ameo 6RG has different BCM or something, I don't know. In Poland it's not possible to order it to 6R hatchback
Ameo is based on same platform of polo 6R
ag69
Post by ag69 »
Can, anybody help me with procuring this clip in UK? (Image attached)
It is on right and left side of dashboard cover.
Also similar metal clips for A pillar? (Image not available)
Lktuning
Drives: Vw Polo 6C 1.0 TSI Highline
Post by Lktuning »
3B0867190 spring clip for dashboard cover
ag69
Post by ag69 »
smg_shardul wrote: Sat Aug 24, 2019 4:28 am
confirmed 5GV-051-629-L works with 6R.
will post images later. again definition of "work" could be interpreted differently ;)
Details shown in app on phone
Software version 9.0.8.0
Database version 37
ag69
Post by ag69 »
ag69 wrote: Sat Sep 21, 2019 10:25 pm Can, anybody help me with procuring this clip in UK? (Image attached)
Got it!!!
ag69
Post by ag69 »
could anyone please me know how to remove terminal from 1J0971972?
I opened a tab and can see small slit and larger slit for each wire.
Somehow using metal Twizzlers, it is not coming out.
Previously for 4D0971636 - 6 pin connector housing, I could push tab of actual terminal - which was visible.
i tried to user terminal removal tools but somehow the connector is not moving at all.
