Polo 6R - Useful Part Numbers
- ag69
- Drives: 1.2TSi 77Kw 7DSG
thanks CNK
- CNK
- Drives: 6R
no problem
A & B should be cheaper, because are older, without AndroidAuto/CarPlay support.
C = 2 USB sockets
D = 3 USB sockets
HSD LVDS wires (e.g. 5Q0035320A from Golf VII) aren't cheap, but you can buy them from aliexpress or local shops.
Female
ed.silmon-monerri
- Drives: 6c 1.4 TDI SE
2014-2015 (on to 2018?) Polo 6c Manual Air-conditioning vent-flap air temperature sensor 6Q0907543F ~£30 from VW Access on RHD for a thinly armed person is 2/3rds of an arms length up between clutch and brake pedal, pointing horizontally left into airbox, needs about 1/2 turn to loosen then it sorta slides out. Connector needs two tiny tabs pinched inward to release. Very few of them around...
Is that the evaporator temperature sensor, used to control the flow of liquid/gas into the evaporator to prevent it from getting down too low in temperature and ending up freezing all the moisture on its face and so blocking the air passing through a bit or a lot?
- ag69
does anyone using 5GV-051-629-J on VW Polo 6R?
Though this could/should be universal component, compatibility list shows Polo but not Polo 6R.
https://shops.volkswagen.com/de_DE/web/ ... 051629j-10
- CNK
- Drives: 6R
Unfortunately it doesn't work with 6R
- ag69
thanks cnk
surprisingly vw India mentions/sells this for VW Polo/Vento variants which are 6R based
https://www.volkswagen.co.in/en/accessories/polo.html
there is a section "Volkswagen Connect" and this is listed.
- CNK
- Drives: 6R
maybe this Ameo 6RG has different BCM or something, I don't know. In Poland it's not possible to order it to 6R hatchback
smg_shardul
- Drives: Polo 6R
You can use to polo 6Rag69 wrote: Fri Aug 23, 2019 7:14 am does anyone using 5GV-051-629-J on VW Polo 6R?
smg_shardul
- Drives: Polo 6R
Ameo is based on same platform of polo 6RCNK wrote: Fri Aug 23, 2019 1:17 pm maybe this Ameo 6RG has different BCM or something, I don't know. In Poland it's not possible to order it to 6R hatchback
- ag69
Can, anybody help me with procuring this clip in UK? (Image attached)
It is on right and left side of dashboard cover.
Also similar metal clips for A pillar? (Image not available)
Lktuning
- Drives: Vw Polo 6C 1.0 TSI Highline
3B0867190 spring clip for dashboard cover
- ag69
confirmed 5GV-051-629-L works with 6R.smg_shardul wrote: Sat Aug 24, 2019 4:28 amYou can use to polo 6Rag69 wrote: Fri Aug 23, 2019 7:14 am does anyone using 5GV-051-629-J on VW Polo 6R?
will post images later. again definition of "work" could be interpreted differently
Details shown in app on phone
Software version 9.0.8.0
Database version 37
- ag69
Got it!!!ag69 wrote: Sat Sep 21, 2019 10:25 pm Can, anybody help me with procuring this clip in UK? (Image attached)
- ag69
could anyone please me know how to remove terminal from 1J0971972?
I opened a tab and can see small slit and larger slit for each wire.
Somehow using metal Twizzlers, it is not coming out.
Previously for 4D0971636 - 6 pin connector housing, I could push tab of actual terminal - which was visible.
i tried to user terminal removal tools but somehow the connector is not moving at all.
