RLS ,CH/LH , Auto lights , Rain sensing wiper & Auto dimming Rear view mirror on Vento
Jerryncg93
Drives: Volkswagen Vento 1.2 tsi
Re: RLS ,CH/LH , Auto lights , Rain sensing wiper & Auto dimming Rear view mirror on Vento
Post by Jerryncg93 »
Confirmed have wires in all 10 slots.
Jerryncg93
Jerryncg93 wrote: Mon Jul 08, 2019 11:13 am As the previous set of rls doesn't work very well, the seller has sent me another set of rls. This time it's 5k7 955 559b, but the sensor seems to be very dirty, may I know how can I clean it up?
What kind of glue should I use to paste the bracket to my windscreen? I'm planning to stick a black sticker with the shape of the cover then paste the bracket onto the sticker, dunno if it works?
can you guide me on this?
Clean the gel foil for the rain sensor with distilled/clean water.
-Do not use cloth, use your finger moistened abundantly with distilled water.
-Do not touch the gel foil with dry fingers.
-Prevent water from coming into contact with the electronic part of the sensor.
-Dry with air if required.
The procedure you have in mind to stick the bracket is not appropriate, it will not work. The black sticker can not hold the weight of the mirror.
Examples:
viewtopic.php?f=56&t=58703&p=502496#p502568
viewtopic.php?f=56&t=70545&hilit=slavik ... 90#p534599
Look for more information with your browser.
Primer and glue (2k).
Jerryncg93
ciclo wrote: Wed Jul 10, 2019 8:20 am Clean the gel foil for the rain sensor with distilled/clean water.
Examples:
Is the primer makes the area black in color? I can't find the original 2k glue here in Malaysia, perhaps i'll go for aftermarket brands for it.
Jerryncg93
Examples:
Can I have your email or telegram/whatsapp please? Easier to communicate.
You are hijacking this thread, please open your thread.
There are many people who can help you, I dont have to be the only one to help you.
Jerryncg93
Ok noted, apologies.
For Shardul's friend:
1- IMP: Please read the information contained in the previous image. Thanks.
2- Installation guide: https://drive.google.com/file/d/1a85zOl ... sp=sharing.
All the information of payment and shipping processes by email. (as always)
Shardul, now I will send the information to your email. Greetings.
About the new codings for Vishwajeet 6R
New RLS coding (5K7)
0728DD
New BCM Max coding (LED headlights)
When the new wiring looms has been installed you have to tell me the type of bulbs/lights installed just at that moment.
I can do a BCM coding for LED headlights at this time, but it makes no sense because it all depends on the moment of the installation process that you have completed.
Jerryncg93
I've tried the coding 0728DD on the 5k7955559B rls, it says code accepted, but when I close and reopen, it remains the same coding as before. Is there any problem with my rls?
Also, when I put it on auto mode, the headlight will switch on, but the instrument cluster, and some other lights wouldn't switch on as the previous thread.
I will not give you help until you open a new thread. I've told you three times.🤷‍♂️
Your problems with RLS have easy answers.
Please don't use the threads of other users. Thank you.
Jerryncg93
ciclo wrote: Sat Aug 03, 2019 10:06 am I will not give you help until you open a new thread. I've told you three times.🤷‍♂️
Sorry, I don't understand you previously. I will open a new thread.
smg_shardul
Drives: Polo 6R
Post by smg_shardul »
ciclo wrote: Thu Aug 01, 2019 6:16 am About the new codings for Vishwajeet 6R
0728DD
Hey ciclo how are you?
Due to floods in our city installation is delayed
Today we finished with all wiring, car assembly is in progress
Few terminals of bcm are not getting locked in T73 Connector , I am attaching pic of the the terminal.
This terminal is not getting locked in T73
I am about to receive LED Light BCM, can I use regular BCM Max till I receive the led BCM?
If so what coding I should use to work led lights with BCM Max
Some reason is there for the terminals not to be blocked. No matter, with a cutter, slightly open the terminal locking tabs so that they perform their blocking function in the connector slot.
New BCM Max coding for LED headlights, etc (Vishwajeet):
3AB02BBF48A10000013806906CEB96900000604F60CD3961210000030020
New RLS coding:
0728DD
Nothing will break if you install a BCM Max that does not support LED headlights.
Email from shardul. :wink:
smg_shardul wrote: Mon Sep 09, 2019 10:40 am
We have installed your wires in Vishwajeet Polo in august itself but full installation was pending due to shortage of auto light switch & RLS Sensor & BCM Max for LED lights.
Finally we have arranged all required parts & installation is completed today
We have upgraded following things
1) BCM Max
2) GTi Full LED Headlamp.
3) Frameless Auto dimming mirror
4) RLS Sensor.
5) Auto Switch.
6) Coming home / Leaving Home
7) Dimmer Switch.
Please find the attached file for latest VCDS Scans report and let me know if i require any changes in coding of BCM.
 Thursday,21,May,2020,17:50:12:00009
VCDS Version: 19.6.1.0 (x64)
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: WVWE1460XFT0XXXXX   License Plate: VISHWAJEET LATEST
Mileage: 72490km-45043mi   Repair Order:
Chassis Type: 60-VW25 (7E0)
Scan: 01 03 08 09 15 17 19 25 44
VIN: WVWE1460XFT0XXXXX   Mileage: 72490km-45043miles
Address 01: Engine (J623-CWXA)       Labels: None
   Part No SW: 03L 906 023 QT    HW: 03L 907 425 B
   Component: R4 1.5l TDI   H33 9977
   Revision: --H33---    Serial number:
   Coding: 00110116030500080000
   Shop #: WSC 01234 785 00200
   ASAM Dataset: EV_ECM15TDI02103L906023QT 001004
   ROD: EV_ECM15TDI02103L906023QT.rod
   VCID: 081F2D27B333320FD1-805C
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 6R0 907 379 BF    HW: 6R0 907 379 AQ
   Component: ABS9.0 front  H01 0001
   Serial number: --------------
   Coding: 60DD2763412418C0061CE46B825218020000
   ASAM Dataset: EV_Brake1ABS90BOSCH 003017
   ROD: EV_Brake1ABS90BOSCH_VW25.rod
   VCID: 03053A0B8A15115784-8056
   Part No SW: 6R0 907 044 P    HW: 6R0 907 044 P
   Component: Climatronic   H12 0614
   Revision: V0000000
   VCID: 408FF507D383CA4FD9-8014
   Revision: B9084001    Serial number: 2502 179190141
   Coding: 3A904BBF48A10000013807007ECB9E901080606F60CD79F1210400030020
   Shop #: WSC 12345 123 12345
   VCID: 2D51BCB37411372702-8078
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 220517 04  42  0106
   Coding: 0728DD
   Subsystem 2 - Part No SW: 6R0 959 802 AL    HW: 6R0 959 802 AL  Labels: 6R0-959-802.CLB
   Component: -------------  006 5550
   Serial number: 13102576140311183853
   Coding: 010000
   Subsystem 3 - Part No SW: 6R0 959 801 AH    HW: 6R0 959 801 AH  Labels: 6R0-959-801.CLB
   Serial number: 13202579140318223016
   Coding: 010000
   Subsystem 4 - Part No SW: 6C0 959 442     HW: 6C0 959 442
   Component: E221__MFL-TAT  H03 0015
   Serial number: 1181417463701494AB1B
   Coding: 240000
   Subsystem 5 - Part No SW: 6R0 959 811 L    HW: 6R0 959 811 L
   Serial number: 13102580140305104947
   Coding: 020000
   Subsystem 6 - Part No SW: 6R0 959 812 L    HW: 6R0 959 812 L
   Serial number: 13102581140325052359
   Coding: 020000
   Revision: --------    Serial number: 003GW00SWL58
   Coding: 003036
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4999E823E8B90B070E-801C
   Part No SW: 6RF 920 860 P    HW: 6RF 920 860 P
   Component: KOMBI         H02 0152
   Coding: 150800
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04719
   VCID: 57BD3E5B2E0D6DF788-8002
   Revision: B9084001
   Coding: 102300
   VCID: 68DF0DA79B73D20F31-803C
   Component: IMMO          H02 0152
   Serial number:
   Shop #: WSC 00000 000 00000
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADB77AF8D7FE01F27-803E
Address 44: Steering Assist (J792)       Labels:* 6Rx-909-144-V1.clb
   Part No SW: 6RF 909 144 K    HW: 6RF 909 144 J
   Component: EPS_ECU       H44 0401
   Coding: 0000
   ASAM Dataset: EV_SteerAssisUDSNSK 005005
   ROD: EV_SteerAssisUDSNSK.rod
   VCID: 54A7C9573FFB46EF6D-8000
End-------------------------(Elapsed Time: 02:07)--------------------------
8) 8)
Hello Shardul, everything is correct regarding the electrical installations and coding mentioned.
Except:
- The CCS is activated in the BCM, but not in the ECU. :?:
- Please, can you explain to me why you have Byte0 Bit4 enabled in the Gateway?
I ask you my sincere apologies for the time it took to answer your request by email, I am trying to respond to all those emails that have a technical character.
I'm sorry with all my heart.💗
