Adaptive front light Syst (AFS) Failure
govindsharma
Drives: polo 1.2 petrol HighLine
Post by govindsharma »
Good Morning everyone I had new error in my car IC image attached.I did not know why it comes. When i attached VCDS i had found error in headlight range (55) log is under.When i want to feed original coding there is an error which is attached under.please tell me how can i get rid of it.
Thank you to all in advance .
Address 55: Headlight Range (J431) Labels: 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0000000000000000
Shop #: WSC 00000 000 00000
VCID: 77FD81BACE0C6EFA91-8022
3 Faults Found:
10490624 - No End-of-Line Programming
B2013 00 [137] - -
Fault Status: 00000001
Fault Priority: 1
Fault Frequency: 1
Reset counter: 24
Mileage: 10618 km
Date: 2019.10.28
Time: 12:54:55
13636352 - Control module not coded
U1013 00 [137] - -
Fault Priority: 1
Fault Frequency: 1
Reset counter: 24
Mileage: 10618 km
Date: 2019.10.28
Time: 12:54:55
5275220 - Headlight
C107E 54 [137] - Missing Calibration / Basic Setting
Fault Priority: 1
Fault Frequency: 1
Reset counter: 24
Mileage: 10618 km
Date: 2019.10.28
Time: 12:54:55
hmthakur
Drives: Polo gt tsi 1.2 dsg
Re: Adaptive front light Syst (AFS) Failure
Post by hmthakur »
From where did you get the headlight range control module ?? dont tick headlight light control in installed components list then try original coding
Has it always done this or did the module work before?
govindsharma
It has working earlier but after update it is not coding .I had updated its firmware that i had downloaded from erwin with this FL_6R0907357___0070.frf firmware.i had tried as you suggested hmthakur but not get succeed .
hmthakur
Post by hmthakur »
Have you saved earlier firmware ?? If yes, try reverting to it. Try getting firmware from person owning polo with headlight range control.
You probably uploaded a corrupt software. Try to revert it
govindsharma
I had not taken backup of firmware .Is there any other method to revert it .From where i can download its firmware any idea.
From what I can see in this thread, that unit is correctly flashed with the correct FW (not corrupt).
I guess the first thing to do is the basic setting... I'm not sure, because I never had to.
hmthakur
Post by hmthakur »
ciclo wrote:From what I can see in this thread, that unit is correctly flashed with the correct FW (not corrupt).
I had installed afs bought used it was from polo gti. I showed error only for basic setting it never showed above error
Go to the VW dealer, maybe that unit needs to be parameterized after you flashed it.
(in case it is possible to recover the missing parameters)
hmthakur
Post by hmthakur »
ciclo wrote:Go to the VW dealer, maybe that unit needs to be parameterized after you flashed it.
That is why i asked him from where did he get this module ?? Was it parameterised or not?? It seems he himself tried to parameterise it
govindsharma
ciclo wrote: Wed Oct 30, 2019 3:09 pm Go to the VW dealer, maybe that unit needs to be parameterized after you flashed it.
I had also read many topic which says that parameterization required after flashing. But parameter file is not with me if anyone in forum have parameter file please provide me.
Thank you.
Have you looked at the file management of VCP activator ? in case you have the original VCP.
Wait, I will look to make sure, but I think this file is not available.
The parameters are only available for module 6R0 907 357 C, and I think they are for Polo SEDAN/VENTO (please, someone correct me if I'm wrong).
govindsharma
Yes sir it is only for C version I had used this xml file but did not succeed. ODIS E refused to flash.
