Benzinkopf's 2012 VW POLO 6R MK5 1.2TSI 105HP DSG
benzinkopf
Drives: 1.2TSI 105HP DSG7
Re: Benzinkopf's 2012 VW POLO 6R MK5 1.2TSI 105HP DSG
Post by benzinkopf »
thanks guys. Maybe i now got another reason to go for HBA. so the Climatronic get a new friend with RLHS. [emoji2960]
benzinkopf
Help needed!
hello everybody, need some helps here with one error and coding/adaptation channel for 08-auto hvac
Thursday,26,December,2019,23:15:10:15298
VCDS Version: 19.6.2.0 (x64)
Data version: 20190930 DS308.0
www.Ross-Tech.com
Workshop Code: 123 12345 012345
VIN: WVWZZZ6RZCUBENZIN   License Plate:
Mileage: 284810km-176972mi   Repair Order: 191226
Chassis Type: 6R-VW25 (01 - BENZIN)
Scan: 01 02 03 04 08 09 10 15 17 19 25 2E 37 3C 44 55 56 65 6C 77
VIN: WVWZZZ6RZCUBENZIN   Mileage: 284810km-176972miles
Address 01: Engine (J623-CBZB)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 HF    HW: 03F 907 309 J
   Component: SIMOS10.22H03 2698
   Revision: --H03---    Serial number:
   Coding: 002500F6202400080000
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_ECM12TFS02103F906070HF 004004
   VCID: 6DDBC694BCAA3C277C-8038
Readiness: 0010 0001
Address 02: Auto Trans        Labels: 0AM-927-769.clb
   Part No SW: 0AM 300 060 G    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 5270
   Revision: 00043014    Serial number: CU501411296648
   Coding: 0000020
   Shop #: WSC 25802 001 1048576
   VCID: 2E590198BA2C873F05-50C8
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 230228E3416E00B4C42C14E382D800801700
   VCID: 0717943CB216F677E6-8052
   Part No SW: 6R0 907 044 Q    HW: 6R0 907 044 Q
   Component: Climatronic   H12 0615
   Revision: V0000000
   VCID: 41834A24D8B20847E8-8014
   Part No SW: 7E0 937 090 B    HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001    Serial number: 0982 259161638
   Coding: 3CB02BFF48A10C0013FF0F917EEB9FD9DAC0672F602D30D0200400130800
   VCID: 2A510D8845C4EB1FD9-807E
   Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 180812 05  54  0403
   Coding: 07302D
   Subsystem 2 - Part No SW: 6R0 959 802 BH    HW: 6R0 959 802 BH  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  003 8612
   Serial number: KU0KU028041441182089
   Coding: 1400A3
   Subsystem 3 - Part No SW: 6R0 959 801 BC    HW: 6R0 959 801 BC  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  003 8612
   Serial number: KU0KU008051441286886
   Coding: 0400A3
   Subsystem 5 - Part No: 1K8 951 171 A
   Subsystem 6 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B
   Component: E221__MFL-TAS  H30 0032
   Serial number: 0122863
   Coding: 830000
   Subsystem 7 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU030061100015373
   Coding: 08BC32
   Subsystem 8 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU001071100015810
   Coding: 08BC32
1 Fault Found:
00975 - Heated Rear Window (Z1)
            011 - Open Circuit - Intermittent
                    Fault Status: 00101011
                    Fault Priority: 3
                    Fault Frequency: 8
                    Reset counter: 50
                    Mileage: 284803 km
                    Time Indication: 0
                    Date: 2024.14.01
                    Time: 00:02:50
Address 10: Park/Steer Assist (J446)       Labels:* None
   Part No SW: 18D 919 475     HW: 56D 919 475
   Component: PARKHILFE 8K  H02 0005
   Revision: --------    Serial number: 20221617004119
   Coding: 308001
   ASAM Dataset: EV_EPHVA18VW3218CS0 001001
   ROD: EV_VW75XParkAssis8K_VW31.rod
   VCID: 70E5DFE0AB98D1CF57-8024
   Component: VW10Airbag027 H09 0020
   Revision: --------    Serial number: 003GX00RY8XP
   Coding: 003237
   Shop #: WSC 31414 790 31414
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4A916D08ED84CB1F39-801E
   Serial number: 3575HRB405H0IRE2COP8
   Serial number: 3585HRB405J0ISD6C8T3
   Serial number: 3515RRB405J0LMIQ6PBL
   Serial number: 3525RRB405H0LMIQCGRX
   Part No SW: 6RD 920 870 A    HW: 6RD 920 870 A
   Component: KOMBI         H05 0805
   Coding: 141C01
   VCID: 4797543CFE96367726-8012
1 Fault Found:
12658432 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 36
                    Reset counter: 50
                    Mileage: 284803 km
                    Date: 2019.12.26
                    Time: 00:02:10
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Coding: 702305
   VCID: 68D5B7809B48190F0F-803C
   Component: IMMO          H05 0805
   Shop #: WSC 00000 000 00000
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6AD1CD888D442B1F19-803E
   Part No SW: 5N0 035 342 E    HW: 5N0 035 342 E
   Component: SG EXT.PLAYER H13 0240
   Revision: A1001003    Serial number: 7660415697
   Coding: 010000
   VCID: 2953F28440C2E007D0-807C
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 1T0 035 680 L    HW: 1T0 035 680 D
   Component: RNS-MID       H70 5274
   Revision: AB001001    Serial number: VWZ6Z7M2235046
   Coding: 04000402040000A00001
   VCID: 377724FC867646F756-8062
   Subsystem 1 - Part No: 7L6 919 859 J
   Component: SIMA V4  7769
Address 3C: Lane Change (J769)       Labels:| 5Q0-907-566.clb
   Part No SW: 7E0 907 566 C    HW: 4H0 907 566 F
   Component: SWA Master    H06 0030
   Serial number: 0372892839
   Coding: 030312
   ASAM Dataset: EV_LaneChangAssis 001028
   ROD: EV_LaneChangAssis_VN75.rod
   VCID: 30651FE06B1891CF17-8064
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 7E0 907 568 C    HW: 4H0 907 568 F
   Component: SWA Slave  H08 0030
   Serial number: 0432634593
   Coding: 030312
3 Faults Found:
267776 - Data Set Implausible
          B2012 00 [009] - -
                    Fault Priority: 3
                    Fault Frequency: 4
                    Reset counter: 10
                    Mileage: 284803 km
                    Date: 2019.12.26
                    Time: 00:06:59
729349 - Control Module for Lane Change Assistance
          C1114 54 [009] - Missing Calibration / Basic Setting
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 8
                    Mileage: 284803 km
                    Date: 2019.12.26
                    Time: 00:01:44
729605 - Control Module 2 for Lane Change Assistance
          C1115 54 [009] - Missing Calibration / Basic Setting
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 8
                    Mileage: 284803 km
                    Date: 2019.12.26
                    Time: 00:01:44
   Part No: 6R0 423 156 B
   Coding: 11230
   Shop #: WSC 31414
   VCID: 2F671C9CEA268E370E-807A
   Revision: --------    Serial number: --------------
   Coding: 0316000001000000
   VCID: 77F7E4FCCEF686F796-8022
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
   Serial number: 30000000023712
   ROD: EV_RDKBERU30_005.rod
   VCID: 377724FC8E7646F756-8062
Address 6C: Back-up Cam.        Labels: 5N0-907-441.clb
   Part No SW: 3AE 907 441     HW: 3AE 907 441
   Component: J772__Rearview      0020
   Revision: 00H13000    Serial number: 525PA8-J41D320
   Coding: 0020006
   VCID: 72E1D5E86D94E3DFA1-8026
Address 77: Telephone (J412)       Labels:| 7P6-035-730.clb
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007663752927
   Coding: 0A10000000010110
   Shop #: WSC 43038 123 12345
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3A713DC8BD645B9FA9-806E
End-------------------------(Elapsed Time: 04:30)--------------------------
a) recently i scanned the car and found out there's error in my 09-Bcm, which is
Fault Priority: 3
Fault Frequency: 8
Reset counter: 50
Mileage: 284803 km
Time Indication: 0
Date: 2024.14.01
Time: 00:02:50
i've check the wiring connection at the rear hatch, but everything looks fine. I tested switching on the heater and it seems to function correctly. any idea where i should start looking at?
b) i retrofitted climatronic to my 6R using parts from locally produced vento.turned out the vento is not using G263 Evaporator Temperature Sensor.Therefore, my externally regulated A/C compressor with N280 never stop compressing till my LowPressure pipe and evaporator freezed up and block the air flow. So i checked again the measuring block and its clear there's no reading from G263 and it never report any fault. So i installed the G263 but still there's no reading. Luckily, i changed adaptation channel 9 from 0 to 1, and it is now getting the reading from G263 and shut-off the compressor when temperature drops around -2/-3 degree celcius. so now, i would like to know whether my adaptation channels setting are correct for my car and it would be good if someone with climatronic can share the value for adaptation channel 0 to 9. As far as i understand, there are channels to set either the car equipt with start/stop, hard-wired radiator fan or not, externally regulated compressor or not etc. but since there's no label in vcds, i've no idea.
c) anyone knows the security access code for 08-Auto hvac?
Adaptation channels, made in the stone age.🐵
Thursday,24,December,2015, Climatronic H11 0711
	SW:6R0-907-044-H   HW:6R0-907-044-H ---  Auto HVAC
	Component:Climatronic   H11 0711, Coding:
	Thursday,24,December,2015,08:32:17:05031
	VCDS Version: Release 15.7.1 (x64)  Data version: 20150904
	VCID: 3878B0CF8B402CFEA5-806C
Channel,,Field 1,Field 2,Field 3,Field 4,
01,0,N/A,N/A,N/A,N/A,
02,0,N/A,N/A,N/A,N/A,
03,1,N/A,N/A,N/A,N/A,
04,,ERROR:,Channel 04,Not,Available,
05,0,N/A,N/A,N/A,N/A,
06,0,N/A,N/A,N/A,N/A,
07,0,N/A,N/A,N/A,N/A,
08,,ERROR:,Channel 08,Not,Available,
09,,ERROR:,Channel 09,Not,Available,
10,,ERROR:,Channel 10,Not,Available,
etc...
255,,ERROR:,Channel 10,Not,Available,
SA... 20103?
BCM
	SW:7E0-937-090-E   HW:7E0-937-090-E ---  Cent. Elect.
	Component:BCM PQ25 Max4 H84 0772, Coding:3CB02FBF48E12400B3380F317CEB9FD05AC0670F600D39D0220400030800
	Thursday,17,October,2019,15:49:58:32438
	VCDS Version: Release 19.6.2 (x64)  Data version: 20190930 DS308.0
	VCID: 2D07F4C8BD16D50F521-8078
02,,ERROR:,Channel 02,Not,Available,
04,1,N/A,N/A,N/A,N/A,
08,1,N/A,N/A,N/A,N/A,
09,0,N/A,N/A,N/A,N/A,
10,0,N/A,N/A,N/A,N/A,
:arrow: 090C adapt
benzinkopf
Thanks ciclo. now i can see that only channel 3 is 1 in your climatronic while there’s no adaptation channel 9.
So far, i follow the same. It seems to work. just that after long drive (30-45mins) still get the freezing coil. will monitor further. perhaps my expansion valve or regulator valve n280 is not doing well.
btw. as far as I found
adaptation channel
1: car with start/stop function
2: moisture sensor installed
3: radiator fan hardwired
4: N/A
5: unknown. something to do with auto mode system.
6: unknown.
7: enabled Air Recirculation always On even in Auto Mode.
8: unknown. something to do with auto mode system (**iichel’s value is 10)
9: enabled evaporator temperature sensor
and 20103 is not accepted for SA.
Good luck with your inquiries.
I think I remembered that I changed some value in the adaptation channels shown previously, but I don't remember if a SA code was necessary, unfortunately I didn't do a new reading of the channels from this unit since those dates.
I will do it when possible, which will be complicated during these dates. (party time :lol:)
benzinkopf
totally understood ciclo. just not the right time. but its ok. when i searched about climatronics. i do find it is less discussed in details. anyway, you re right. adaptation channel still can be changed without SA. i’m just asking since the labelled in Odis showed channel 4 is for externally regulated compressor while the channel is not available. Even inside odis, there’s nothing can be done with channel 4.
benzinkopf
new year gift[emoji3061][emoji2957].
ciclo wrote: Sat Dec 28, 2019 7:56 am Good luck with your inquiries.
Tuesday,31,December,2019
	Tuesday,31,December,2019,11:54:01:32438
	VCID: 3829D59C425460A7317-806C
02,1,N/A,N/A,N/A,N/A,
11,,ERROR:,Channel 11,Not,Available,
etc...
Nothing to highlight ... :arrow: viewtopic.php?f=56&t=58703&p=519664#p519664
benzinkopf
thank you my friend. Really appreciate the adpmap. So its clear that its adapted to RLHS with channel 2 and the channel 3 is clear for the hardwired fan system. So I followed the channel 3 with value 1. Later on, once i upgrade to RLHS and HBA, i know i need to enable channel 2. [emoji1362]
Everything seems to be working great so far with my climatronic. Just that based on measuring value, i find out that the pressure regulation by N280 is not that great, at high speed, it’s still pumping the refrigerant to a level that its easy to freeze. I’m waiting for the part now (N280 valve) to replace. Hopefully all good. If not, its gonna be a new compressor[emoji23]
benzinkopf
Hello everybody!
I need another help again. lol. Hopefully our experts here can help me with 2 issues i have now. (especially ciclo, iichel, cnk, madwarlock, gowind, and all others)
1) AFS Module flashing & parameterization using ODIS E.
today i did stupid things. doing something i dont ve any knowledge. A friend of mine asked for help to flash one door module in his golf using his odis E 9.0.4. I’ve no idea really. so i will need to try and test and learn. So i decided why not and try flashing my AFS module using odis e flash function. I got the file from Erwin (thanks to Gowind) and i did the flashing and all seems good. But little i know that i need to write the dataset and parameterization for the module before i can code it normally using vcds. now im stuck and dont know what and how. My AFS is giving error and flashing the warning light. lol. [emoji2361]. is there any way i can correct this or i really need to look for a new module?
2) RLHS upgrade
So today i received my new RLHS sensor, as this from China, i always immediately test plug in the new sensor to check its condition.
here’s my new VCDS scan
 Wednesday,15,January,2020,17:40:54:15298
www.Ross-Tech.com
VIN: WVWZZZ6RZCUBENZIN   License Plate: BENZIN
Mileage: 286280km-177886mi   Repair Order: 200115
VIN: WVWZZZ6RZCUBENZIN   Mileage: 286280km-177886miles
Readiness: 0000 0000
   Coding: 0000020
   Revision: --------
   Revision: V0000000
   Coding: 3CB02BFF48A10C0013380F917EEB9FD9DAC0672F602D30D0200400130800
   Component: RLHS 231117 0  47  0106
   Coding: 0728DD
   Coding: 1400A3
   Coding: 0400A3
   Coding: 830000
   Coding: 08BC32
   Coding: 08BC32
1 Fault Found:
            000 - -
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 286284 km
                    Time Indication: 0
                    Date: 2024.14.21
                    Time: 17:30:56
   Coding: 308001
   Coding: 003237
   Coding: 141C01
1 Fault Found:
          U1111 00 [008] - -
                    Fault Priority: 6
                    Fault Frequency: 20
                    Reset counter: 114
                    Mileage: 286248 km
                    Date: 2020.01.15
                    Time: 13:23:36
   Revision: B9081001
   Coding: 002305
   Coding: 010000
   Coding: 030312
   Coding: 030312
3 Faults Found:
          B2012 00 [009] - -
                    Fault Priority: 3
                    Fault Frequency: 5
                    Reset counter: 74
                    Mileage: 286248 km
                    Date: 2020.01.15
                    Time: 14:34:07
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 73
                    Mileage: 286248 km
                    Date: 2020.01.15
                    Time: 13:21:36
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 73
                    Mileage: 286248 km
                    Date: 2020.01.15
                    Time: 13:21:36
   Coding: 11230
   Shop #: WSC 31414
   Coding: 0000000000000000
3 Faults Found:
10490624 - No End-of-Line Programming
          B2013 00 [137] - -
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 73
                    Mileage: 286248 km
                    Date: 2020.01.15
                    Time: 13:21:37
13636352 - Control module not coded
          U1013 00 [137] - -
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 73
                    Mileage: 286248 km
                    Date: 2020.01.15
                    Time: 13:21:37
5275220 - Headlight
          C107E 54 [137] - Missing Calibration / Basic Setting
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 73
                    Mileage: 286248 km
                    Date: 2020.01.15
                    Time: 13:21:37
   Coding: 0020006
so the installation pretty easy as i just want to check. after install, i change the coding of the RLHS to 0728DD and enabled channel 2 in adaptation climatronic. everything seems to be working except i got error in BCM saying it’s not coded correctly. is there any other byte/bit i need to enable in bcm?
benzinkopf
**Update
So i just found out another error recorded in my Climatronic (presumably due to channel 2 activation, climatronic now waiting for Humidity input from BCM???)
Revision: V0000000
1 Fault Found:
00457 - Central Electronics Control Module / BCM (J519)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 74
Mileage: 286284 km
Time Indication: 0
Date: 2024.14.21
Time: 17:41:35
Is this means the humidity sensor is still not “coded” in the bcm or it’s just a bad sensor?[emoji848]
byte8bit5? hurm
climatronic error 00457 - Control Module for Network (J519) is solved by setting adaptation channel 1 of the HVAC to value 1
climatronic error 00706 - Relay for Coolant Fan; Stage 2 (J513) is solved by setting adaptation channel 2 of the HVAC to value 1
climatronic error 00705 - Relay for Coolant Fan; Stage 1 (J279) is solved by setting adaptation channel 2 of the HVAC to value 1
benzinkopf
ok. i re-googled ciclo’s thread (not sure for how many times. lol). i found out his post for the RLHS need to activate byte8bit5. So i did that. Error gone so far on both bcm n climatronic. [emoji1360]
btw thanks iichel! i didn’t know that channel 2 is for the fan control! i really thot its the humidity sensor. so i havent enable channel 1 inside climatronic yet. will see and update soon.
Excellent 8)
benzinkopf
temporary bracket for testing. [emoji1787]
