DELETE
- Drives: 6C GTI
DELETE
struggling to figure out the wiring for my reverse camera. ive got it all wired through the car but im stuck on these final wires
i have a MIBII unit. my instructions say connect to pos and neg from dvd lines
MIBII doesnt have dvd lines??
Last edited by JaegerStriker on Sat Apr 25, 2020 12:16 pm, edited 1 time in total.
Re: Reverse camera
Use T12/6 and T12/12 of the blue connector of the quadlock. I can't tell you what's the positive and negative though.
- Drives: 6C GTI
Re: Reverse camera
ive found this video. looks like the exact same kit ive got. do you reckon this would be the easier way to connect it
https://www.youtube.com/watch?v=pnpN7ZUtryk
Re: Reverse camera
Could you give me a tl;dr? I don't really feel like watching a 17 minute video
- Drives: 6C GTI
Re: Reverse camera
red into fuse splitter
black into ground?
Re: Reverse camera
Ah yes, my mistake.
Connect the black to the thick brown/white wire (GND)
Connect the red to the thick red wire.
- Drives: 6C GTI
Re: Reverse camera
No the wires will only draw the current they need for the camera.
- Drives: 6C GTI
Re: Reverse camera
So I've tried that. Still doesn't work. I'm going to try the piggy back fuse connection and see if that works. No doubt I'll be back crying for guidanceiichel wrote:No the wires will only draw the current they need for the camera.
Thanks for the help iichel
Sent from my SM-G975F using Tapatalk
- Drives: 6C GTI
Re: Reverse camera
update.
+ wire plugged into a constant power fuse enables to boot to be opened without keys in the ignition
need to get a connector to attach the - wire to a grounding point somewhere
halfway there kinda
halfway there kinda
- Drives: 6C GTI
Re: Reverse camera
update 2
coding shows the camera screen but black.
connecting blue wire to the reverse wire stops the boot from opening
- Drives: 6C GTI
Re: Reverse camera
FIXED
im an idiot
just needed to ground the black cable to a bolt behind the dash cover next to the drivers side door
im an idiot
