I fitted a new carb yesterday (well, an old carb that I know nothing about but had sitting in the shed) as my old one was knackered.. this one runs fine most of the time, doesn't cut out in the cold like the last one did, and seems to be a bit more economical than the last one (although I haven't actually had a chance to work out the mpg yet), there's just one problem, just occasionally when I'm accellerating at a low speed at low revs (ie turning into a junction in 2nd gear), the engine starts running a bit lumpy. The tone of the engine doesn't change, but the power comes and goes in lumps. Also, when I'm accellerating, there seems to be less power than usual until I hit about 2,200 rpm, then it pulls just as it normally would.
Can anyone suggest why it's doing this? Could it just be that the carb's been sat in a shed for a few months and something's a bit sticky? I've flushed it with redex, but I don't know enough about carbs to really know what could be causing this..
Lumpy running
GroovyCarrot
- Sponsor
Gareth_GT_Hatch
- Platinum Member
GroovyCarrot
- Sponsor
The rubber block that the carb sits on, or another seal? I didn't change the rubber thing.. but then I didn't change it last time I took the carb off and it seemed alright, it's in good condition anyway. If you mean another seal.. um.. nope
Fraid not, didn't know there was one. Might just be the problem I guess..
GroovyCarrot
- Sponsor
Yeah, I did a carb flush with redex.. poured about 1/4 bottle in the top and had some fun covering the village in white smoke
I've also got a bit in the petrol tank, I'll stick some more in though.
I'd have a mate take a look at it, but the only person I know who has a clue about cars is my mechanic, and he charges £35/hour, which is about £35 more than I can spend at the moment
Don't suppose spraying wd40 in the top is likely to make a difference?
- bstardchild
- Moderator
Stop messing about and buy this
http://www.tigerstyle.co.uk/poloforum/v ... php?t=8383
Exactly what the doctor ordered
