Brake upgrade
PoloGTI180
- Drives: Polo GTI '13
Brake upgrade
Hello,
I would like to upgrade the brakes of my 6R GTI to 6R WRC, I think that they use same caliper with different bracket and a bigger rotor. Anybody has done this mod?
Thanks.
Thanks.
Re: Brake upgrade
Yep, you need to upgrade the caliper carrier and the disc at the front. But the more tricky part is to code the ABS unit.
There is a coding for a GTI CTHE engine with 312mm fronts and 232mm rears. But it will only work on ESP9.0i and I'm not sure it will accept 312 + CAVE engine.
Re: Brake upgrade
Why would you need to code the ABS? I upgraded my 6R Tdi, from 256mm to 288mm, changed calipers, carriers, rotors, knuckles, the braking difference is day and night i did not recode anything and i haven't noticed any problems...
Sent from my SM-G935F using Tapatalk
Re: Brake upgrade
Because the distribution between front and rear brake pressure meds to be ok for good braking and braking stability
Re: Brake upgrade
Im not an expert but abs sensors measure wheel rotation, its got nothing to do with rotor size...
Re: Brake upgrade
The ABS/ESP unit also divided the brake pressure from the brake pedal between the front and rear axles. I.e.70% to the front and 30% to the rear with 256mm fronts 232mm rears.
If you have larger rotors, 288 instead of 256mm at the front, you want to have lower pressure. If you still have 70/30 the front axle will brake much stronger. So therefore you need i.e. 60/40.
Re: Brake upgrade
Yes ok but due to EBV electronic brake variator, wouldn't the braking force be applied correctly since it reads and adapts on the fly on the braking conditions?
Re: Brake upgrade
No, not until you lock up a wheel or the rear goes really light.
Re: Brake upgrade
Don't know have not noticed anything bad about my setup just much better braking, no early ABS engaging or other noticable problems, i will ask a brake specialist though when i have the chance...
Re: Brake upgrade
If you have VCDS or something similar, you can also adjust the coding of the abs yourself.
Re: Brake upgrade
The headlights ?!?!?!
Re: Brake upgrade
the abs. sorry. I'm doing 27 things at the same time. i corrected it.
Re: Brake upgrade
Lol no problem mate, i have obd11, but i wouldn't know what number to code on ABS...
Re: Brake upgrade
Can you post your current long coding of the abs?
Re: Brake upgrade
Let me see if i can pull it from obd11 offline...
