Brake upgrade
PoloGTI180
Drives: Polo GTI '13
Brake upgrade
Post by PoloGTI180 »
Hello,
I would like to upgrade the brakes of my 6R GTI to 6R WRC, I think that they use same caliper with different bracket and a bigger rotor. Anybody has done this mod?
Thanks.
Re: Brake upgrade
Yep, you need to upgrade the caliper carrier and the disc at the front. But the more tricky part is to code the ABS unit.
There is a coding for a GTI CTHE engine with 312mm fronts and 232mm rears. But it will only work on ESP9.0i and I'm not sure it will accept 312 + CAVE engine.
grpolo
Drives: 6R
Re: Brake upgrade
Post by grpolo »
Why would you need to code the ABS? I upgraded my 6R Tdi, from 256mm to 288mm, changed calipers, carriers, rotors, knuckles, the braking difference is day and night i did not recode anything and i haven't noticed any problems...
Sent from my SM-G935F using Tapatalk
Re: Brake upgrade
Because the distribution between front and rear brake pressure meds to be ok for good braking and braking stability
grpolo
Drives: 6R
Re: Brake upgrade
Post by grpolo »
Im not an expert but abs sensors measure wheel rotation, its got nothing to do with rotor size...
Re: Brake upgrade
The ABS/ESP unit also divided the brake pressure from the brake pedal between the front and rear axles. I.e.70% to the front and 30% to the rear with 256mm fronts 232mm rears.
If you have larger rotors, 288 instead of 256mm at the front, you want to have lower pressure. If you still have 70/30 the front axle will brake much stronger. So therefore you need i.e. 60/40.
grpolo
Drives: 6R
Re: Brake upgrade
Post by grpolo »
Yes ok but due to EBV electronic brake variator, wouldn't the braking force be applied correctly since it reads and adapts on the fly on the braking conditions?
Re: Brake upgrade
No, not until you lock up a wheel or the rear goes really light.
grpolo
Drives: 6R
Re: Brake upgrade
Post by grpolo »
Don't know have not noticed anything bad about my setup just much better braking, no early ABS engaging or other noticable problems, i will ask a brake specialist though when i have the chance...
Re: Brake upgrade
If you have VCDS or something similar, you can also adjust the coding of the abs yourself.
grpolo
Drives: 6R
Re: Brake upgrade
Post by grpolo »
The headlights ?!?!?!
Re: Brake upgrade
the abs. sorry. I'm doing 27 things at the same time. i corrected it.
grpolo
Drives: 6R
Re: Brake upgrade
Post by grpolo »
Lol no problem mate, i have obd11, but i wouldn't know what number to code on ABS...
Re: Brake upgrade
Can you post your current long coding of the abs?
grpolo
Drives: 6R
Re: Brake upgrade
Post by grpolo »
Let me see if i can pull it from obd11 offline...
