reido80
Drives: VW t5.1 GP bitdi 4motion
Post by reido80 »
Fuse box A in ebox
New feed for +30 6mm wire fused 30amp
Ran up original loom and fed through this grommet
Fuse box SB
Fuse box SC
Kufatec loom for ALWR that will be modified to pick up left headlight at T10/T14 and shortened in places. (i think it is specific to left hand drive).
ALWR unit (wrong one I think)
Also have a kufatec loom for rain & light sensors but I think it is wrong but can be made to work.
Also discovered I might have bought the wrong rear view mirror or I am missing another bracket from the windscreen. (Van has no back window in tailgate). I removed the cap from the existing mirror bracket on the windscreen but it seems something is amiss.
Hi reido80.
Let's go with it ...
First thank for all the images and the two Autoscan posted.👌
ID:
Transporter T5. 'D' Model Year (05/2012 - 05/2013)
Wiring diagrams to be used:
-Headlights with halogen bulbs (H4) , (7L3/8K0/8K1/5D0/5D1/5D9) From May 2012 (Chapter 183)
-Headlight with gas discharge light , (8EC),(8ED),(8EM),(8EN) From May 2012 (Chapter 146)
https://drive.google.com/file/d/1z_-f0C ... sp=sharing (download if you need it)
For the wiring from the BCM connectors to the bixenon headlights take into account what was discussed here:
viewtopic.php?f=56&t=70736&start=30#p528541
Because you want to update the auto dimming mirror, I imagine you want to install the auto lights in addition to the bixenon headlights.
My recommendation is that you follow the scheme for H4 for the manufacture of the wiring:
viewtopic.php?f=56&t=70736&start=45#p528663
Automatic lights means having the rain light sensor installed, which is installed in conjunction with the automatic dimming mirror.
There are two ways to install the new auto dimming mirror (+RLS):
- Or you can change the windshield with the appropriate retaining plate for the new mirror.
- Or you install the retaining plate on your current windshield.
e.g. :arrow: https://www.ecstuning.com/b-genuine-vol ... aa845543b/
There are many tutorials on the internet in the various forums dedicated to the VW group.
For the BCM adaptation and the rest of the lights, follow what is indicated here:
viewtopic.php?f=56&t=70736&start=45#p528735
The first thing you should do right now is this:
This is where the BCM adaptation/replacement begins in order to be able to access the information of all the units with the VCDS.
- http://wiki.ross-tech.com/wiki/index.ph ... eplacement
You must matching the remote controls at this time, follow these ross-tech instructions scrupulously.
- http://wiki.ross-tech.com/wiki/index.ph ... ctory_Mode (value = 0)
- http://wiki.ross-tech.com/wiki/index.ph ... l_Clearing
- http://wiki.ross-tech.com/wiki/index.ph ... l_Matching
You do the process for the first remote control, entering the value 0, and then you do the same process for the second remote control, also entering the value 0, and so on with all the remote controls you have.
Once done, make a new autoscan, regardless of the units you have currently uninstalled.
You can now get rid of BCM 087 if it is your wish. :wink:
There are more things to comment, because your new BCM Max (second hand) comes from a vehicle with Start/Stop (7L6), and your T5 is without Start/Stop (7L3), but we will solve this later.
reido80
Post by reido80 »
Many thanks for your help Ciclo, I see now what you mean about the mirror.
I think when it comes to the auto lights, I will just run all the wiring ready to plug in at a later date. Would this be possible? I might change the windscreen for a heated T6 screen with correct sensors at a later date but that's another story.. :D
Ok, so this is where we are at-
Can lines between cluster and bcm-Done Had fun making the twisted wires :D
Keys coded
BCM codes copied from old.
Still have loads of errors, which is understandable, Passenger airbag fault is because the dash warning light is disconnected.
Saturday,01,August,2020,12:48:19:03258
VCDS Version: 20.4.2.0 (x64)  HEX-V2 CB: 0.4513.4
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: WV2ZZZ7HZDH021778   License Plate: 090BCM TEST2
Mileage: 130870km-81318mi   Repair Order:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 10 15 17 18 19 22 25 69 0B
VIN: WV2ZZZ7HZDH021778   Mileage: 130870km-81318miles
18-Aux. Heat -- Status: OK 0000
22-AWD -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
69-Trailer -- Status: Cannot be reached 1100
Address 01: Engine (J623-CFCA)       Labels:. 03L-906-022-CFC.clb
   Part No SW: 03L 906 019 GK    HW: 03L 907 309 L
   Component: R4 2,0L EDC   H37 3566
   Revision: 22H37---    Serial number: 00000000000000
   Coding: 0119401A233600080000
   Shop #: WSC 02756 790 50316
   ASAM Dataset: EV_ECM20BTD01103L906019GK 003003
   ROD: EV_ECM20BTD01103L906019GK_003.rod
   VCID: 7AADF0A04C5F927B1C7-802E
3 Faults Found:
5568 - Sensor for Ambient Air Temperature (G17)
          P0073 00 [039] - Signal too High
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 130877 km
                    Date: 2020.08.01
                    Time: 00:56:09
                    Engine speed: 0.00 /min
                    Normed load value: 0.0 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 16 °C
                    Intake air temperature: 18 °C
                    Ambient air pressure: 990 mbar
                    Voltage terminal 30: 11.960 V
                    Exh.gas temp.sen 1: 20.0 °C
                    Exh.gas temp.sen 2: -0.0 °C
                    Exh.gas temp.sen 3: 20.0 °C
                    Exh.gas temp.sen 4: 20.0 °C
                    Shut-off timer: last engine shut-off time: 3383 s
10065 - Mass Air Flow Sensor (G70)
          P0104 00 [167] - Intermittent
          MIL ON - Not Confirmed - Tested Since Memory Clear
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 130877 km
                    Date: 2020.08.01
                    Time: 00:56:08
                    Air mass: actual value (mg/stroke): 0.0 mg/stroke
                    Standardized airflow ratio: filtered: 3.9999
                    EGR Solen.val.: actual value: 99.89 %
                    Throttle valve adapter: actual value: 104.42 %
                    Charge air pressure specified value: 1020 hPa
                    Charge air pressure: actual value: 994.4 hPa
                    Mean injection quantity: 0.00 mg/stroke
9531 - Manifold / Barometric Pressure Sensor (G71) / (F96)
          P0105 00 [039] - Malfunction
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 130877 km
                    Date: 2020.08.01
                    Time: 00:56:08
                    Charge air pressure: actual value: 990.2 hPa
                    Intake air pressure sensor after air cleaner: raw value: 1150 hPa
                    Sensor for charge pressure between turbochargers: raw value: 994.2 hPa
                    Engine status: COENG_READY
                    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 1
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 J    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0109
   Revision: 00H43001
   Coding: 108764AD19A6089626A99878AA6610
   Shop #: WSC 02756 790 49152
   VCID: 392F2FAC0959596355D-806C
   Part No SW: 7E5 907 047 BG    HW: 7E5 907 047 BG
   Component: Climatic-T5   H20 0505
   Revision: 00001010
   Coding: 0000000002
   ROD: EV_ClimaT5Basis.rod
   VCID: 75B7E39C6541FD03715-8020
1 Fault Found:
13701968 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [Steuergerät im Schalttafeleinsatz - bitte Fehlerspeicher auslesen]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 232
                    Mileage: 130877 km
                    Date: 2020.08.01
                    Time: 00:56:06
Address 09: Cent. Elect. (J519)       Labels:. 7H0-937-08x-09.clb
   Part No SW: 7H0 937 090 D    HW: 7H0 937 090
   Component: BCM PQ25 Max4 H74 0725
   Revision: B9074001    Serial number: 0671 186141457
   Coding: B8B079B80E61241192284E106E6985550080430F60844040320000000000
   Shop #: WSC 02739 790 12345
   VCID: 2F3B11F4C71D87D3FB9-807A
   Subsystem 1 - Part No SW: 7E0 959 801 C    HW: 7E0 959 801 C  Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  003 3313
   Coding: 050000
   Subsystem 2 - Part No SW: 7E0 959 802 C    HW: 7E0 959 802 C  Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  003 3313
   Coding: 050000
   Subsystem 3 - Part No: 7E1 951 172
   Component: DWA-Sensor 00  001 0104
   Subsystem 4 - Part No: 1K0 951 605 C
   Subsystem 5 - Part No: 7E1 951 172
   Subsystem 6 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A
   Component: E221__MFL-TAS  H09 0013
   Serial number: 0390005
   Coding: 820000
3 Faults Found:
03591 - Control Circuit for Horn
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 232
                    Mileage: 130877 km
                    Time Indication: 0
                    Date: 2014.12.23
                    Time: 00:56:07
01516 - Terminal 30; Left
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 232
                    Mileage: 130877 km
                    Time Indication: 0
                    Date: 2014.12.23
                    Time: 00:56:06
00927 - Terminal 30 (Right)
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 232
                    Mileage: 130877 km
                    Time Indication: 0
                    Date: 2014.12.23
                    Time: 00:56:06
   Part No SW: 7E0 919 475 J    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0105
   Revision: --------    Serial number: 28261217200384
   Coding: 118001
   VCID: 392F2FAC09D9596355D-806C
1 Fault Found:
13632256 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerät für Anhängererkennung-J345 - kein Signal/keine Kommunikation]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 232
                    Mileage: 130877 km
                    Date: 2020.08.01
                    Time: 00:56:06
   Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
   Component: VW10Airbag009 H07 0013
   Revision: --------    Serial number: 003HL00CRH9K
   Coding: 000000000000000000000000000000003039
   Shop #: WSC 02754 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3537239C25C1BD03B15-8060
1 Fault Found:
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
          B1016 14 [137] - Open or Short to Ground
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 130877 km
                    Date: 2020.08.01
                    Time: 00:56:08
   Part No SW: 7E0 920 970 G    HW: 7E0 920 970 G
   Component: KOMBI         H06 0605
   Coding: 160E00
   VCID: 2E050CF0C0978EDBF0F-807A
1 Fault Found:
9453330 - Outside temperature sensor
          B103F 1B [009] - Resistance Too High
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 232
                    Mileage: 130877 km
                    Date: 2020.08.01
                    Time: 00:56:06
Address 18: Aux. Heat        Labels: None
   Part No: 7E0 815 071 B
   Component: J737__Standheizung  0605
   Revision: 00085000    Serial number: 09019275F00000
   Coding: 0000031
   Shop #: WSC 02757 790 00000
   VCID: 2411EED892DB348B16B-8070
   Part No SW: 6N0 909 901     HW: 7H0 937 090
   Component: GW-K-CAN TP20 H74 0725
   Revision: B9074001
   Coding: 042300
   VCID: 70B9D2881AA3D82BA23-8024
1 Fault Found:
01517 - Control Module for Trailer/Towing Sensor (J345)
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 232
                    Mileage: 130877 km
                    Time Indication: 0
                    Date: 2014.12.23
                    Time: 00:56:11
Address 22: AWD        Labels: 0AY-907-554-V1.clb
   Part No SW: 09N 907 554 B    HW: 09N 907 554 B
   Component: Haldex 4Motion      6008
   Coding: 0000007
   Shop #: WSC 02756 790 00000
   VCID: 372B2994334D4F13A39-8062
   Component: IMMO          H06 0605
   Serial number:
   Shop #: WSC 12345 123 12345
   ROD: EV_Immo_UDS_VDD_RM09_VW31.rod
   VCID: 6A8DC0E03CFF22FBEC7-803E
Address 69: Trailer
Cannot be reached
End----------(Elapsed Time: 02:04, VBatt start/end: 12.1V/12.1V)-----------
Perfect, everything has changed noticeably even if it doesn't seem like it.
Logically there are many faults due to having some parts/units uninstalled.
These faults will disappear as what is uninstalled is installed.
New faults will also appear when a new BCM coding is done (this will be fixed later).
The donor car's BCM 090D had a Bluemotion system, which means it had a Battery Monitoring Control Module (61).
Module 61 can be removed from the installation list with the following procedure:
1- Go to Gateway 19, installation list, enable 61 (again).
2- Go to Battery monitoring 61 (now enabled), codify to 000000.
3- Come back to Gateway 19, installation list, disable 61.
4- Go to autoscan, click on GW installation list (not on Start), wait the result, clear all DTCs, wait the result ...
Module 61 must have disappeared from the installation list.
5- Check with a new Autoscan (Start button).
reido80 wrote: Sat Aug 01, 2020 1:08 pm Many thanks for your help Ciclo, I see now what you mean about the mirror.
It is possible, but it is to duplicate the work on the connectors, especially on the T17 light switch connector. Better to get rid of this T17 connector now.
I recommend that you install the mirror and rain light sensor now, along with wiring for auto lights.
This is what is proposed in the diagrams for a T5 with xenon headlights.
reido80
Post by reido80 »
Hi folks, hope you have had a good weekend.
Many thanks for the above information and guidance, I will get more bcm coding done once it is safe enough to reconnect the battery. I will order the correct windscreen mount and mirror parts and get all the parts ready for a proper install.
Today's progress, one step forward two steps back kind of day!
Discovered that the laser tools pin extractor is rubbish! I spent a good part of the day messing about with them. The tool pins are just too soft and thin they just wont push the release pins down enough. I cant even remove fuse terminals (I slid the purple cage to the side as much as it would go) so I am on the lookout for a new set of tools.
Cut off the T17 switch plug,
Fitted 10 pin connector to the original T17 wiring. (if I have to remove this I will be in trouble as I tried to take a pin out but the tool just wont work).
Started to make the loom for auto lights and after many hours of fiddling and had crimped the JPT's to the wires I found that I have the wrong plugs/pins for the coupling. Completely my fault and will set me back waiting on more parts. We live and learn...
What i have is vw 10 pin connector 191972725 which is currently fitted with original t17 terminals clicked in. 191972735 is the end that takes the male terminals which I thought should be male JPT 2.8 but I cant get them to click in to this. It looks like it is meant for some other terminal type. Must be similar to JPT but with the pin offset slightly.
If I could ask a question to do with the loom please...
What terminals are needed for the relay holder?
This tool usually works well for many.
https://www.ebay.co.uk/sch/i.html?_from ... ol&_sop=15
I have had one for over 7 years and it works perfectly.
In all technical manuals related to removing terminals, it is commented that some experience is needed to remove the terminals. Patience. :)
Surprisingly, the four tools in the center of the image below are extremely useful for many jobs with small connectors and terminals. Search Aliexpress.
For 191972735
For 8E0937527 or 7M0937632B
reido80
Post by reido80 »
Again, 1000 thankyous Ciclo, :D
New extraction tools should be here tomorrow. (same as you recommended)
Do you know the wire sizes mm2 on those repair wires?
219E
236E
I am going to visit the car breakers yard this week and see if I can get some parts and will have a look for a couple of
those relay holders and cut some wiring for repair wires.
I might have a new windscreen sorted out.
Before I get going with the next part of my plan, I thought I would ask some questions and run it past you if thats ok...
1) Is there anything else you think is worth me doing while I have the van in bits?
Would it be feasible or desirable to run any other wires and further integrate this BCM with other systems?
eg. Could I run wires from the BCM to the rear lights (at the connection points under the seat), Any benefits to this?
I think I need to run a wire from BCM to reverse signal under the seat anyway so things like this wouldn't take long if it had any benefit? (I have factory fit trailer electrics in case this effects anything) (already has multi function steering wheel)
2) When I fit the ALWR loom, it requires connection to BCM T73 B18 & B19 (can high/low?). Could I run these to join at the points behind the instrument cluster where I Isolated the T32 wires when i fitted the twisted yellow black wires from the bcm? I think these are the same signal. Diagram 146/13. *Edit this is what I will do.
3) I need help with the wires in the original H4 halogen loom. (wiring diagram 183/7).
In the right headlamp loom i see that the Yellow cable goes from fuse SB27 to T10ap/6 (56b) low beam. And a white wire goes to T10ap/8 (56a) high beam, so- Yellow low beam, white high beam.
In the xenon wiring diagram (146/8) it is the same. - yellow low beam, white high beam.
(replicated on left side light but fuse SB5 and different colours).
If I was to isolate original SB27 and SB5 and run new wires direct from BCM to xenon T14/6 for low beam, is this going to effect anything else? Would I still need to add a signal to make low beam stay on when high beam is activated?
*Edit - I see that i will still need the high beam signal and will look to see if I can take it from E4 dip/flash switch T41/39
4) I am also going to isolate the original DRL fuses SC12 SC14 (and old T17/3) and reuse these locations for the +30 feed to the BCM T73B/3, T73B/5. (change to 30amp fuses) Then run new wires from bcm to drls.
The reason for 3 & 4 above is because the original loom has been damaged and modified by a previous owner/garage when they incorrectly fitted the xenons.
5) I am thinking of running another +30 feed from SA fuse box (6mm2). This would be so I have a point behind the relay carrier and BCM so I can easily add further additions in the future (dash camera,USB sockets etc). I would use the clip on fuse holder to fit into the relay cage and there is an earth point near by too. I would also utilise the spare +15 from T17 to have a further ready made +15 feed. (ALWR, rain sensor).
If I do this I can also use this new +30 fuse holder to feed the new Auto lights relay pin 3 (which would be next to it).
reido80
Post by reido80 »
Ok So got a little bit more done today,
Ran a new 6mm cable to rear of bcm area for extra +30 supply if needed.
Removed Battery Regulator from Installation list.
VIN: WV2ZZZ7HZDH0   License Plate: BATREG 61 REMOVED
VIN: WV2ZZZ7HZDH0   Mileage: 130870km-81318miles
3 Faults Found:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 130877 km
                    Date: 2020.08.06
                    Time: 00:14:38
                    Coolant temperature: 19 °C
                    Intake air temperature: 20 °C
                    Exh.gas temp.sen 1: 23.8 °C
                    Exh.gas temp.sen 3: 23.8 °C
                    Exh.gas temp.sen 4: 21.9 °C
                    Shut-off timer: last engine shut-off time: 886 s
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 130877 km
                    Date: 2020.08.06
                    Time: 00:14:37
                    EGR Solen.val.: actual value: 99.68 %
                    Throttle valve adapter: actual value: 104.48 %
                    Charge air pressure: actual value: 1003.0 hPa
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 130877 km
                    Date: 2020.08.06
                    Time: 00:14:37
   Revision: 00H43001
   Revision: 00001010
   Coding: 0000000002
1 Fault Found:
          U1113 00 [009] - -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 232
                    Mileage: 130877 km
                    Date: 2020.08.06
                    Time: 00:14:35
   Coding: 050000
   Coding: 050000
   Coding: 820000
3 Faults Found:
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 232
                    Mileage: 130877 km
                    Time Indication: 0
                    Date: 2014.12.28
                    Time: 00:14:36
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 232
                    Mileage: 130877 km
                    Time Indication: 0
                    Date: 2014.12.28
                    Time: 00:14:35
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 232
                    Mileage: 130877 km
                    Time Indication: 0
                    Date: 2014.12.28
                    Time: 00:14:35
   Coding: 118001
1 Fault Found:
          U1111 00 [009] - -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 232
                    Mileage: 130877 km
                    Date: 2020.08.06
                    Time: 00:14:36
1 Fault Found:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 130877 km
                    Date: 2020.08.06
                    Time: 00:14:37
   Coding: 160E00
1 Fault Found:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 232
                    Mileage: 130877 km
                    Date: 2020.08.06
                    Time: 00:14:34
   Coding: 0000031
   Revision: B9074001
   Coding: 042300
1 Fault Found:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 232
                    Mileage: 130877 km
                    Time Indication: 0
                    Date: 2014.12.28
                    Time: 00:14:39
   Coding: 0000007
   Serial number:
Address 69: Trailer
Cannot be reached
End----------(Elapsed Time: 02:06, VBatt start/end: 12.1V/12.1V)-----------
New terminal removal tools arrived and so far so good on the fuse box. It is fiddly but once you get the knack, its not so frustrating. Biggest problem was the pink locking device. Even though it has clicked out of the lock position it still needs levered a bit further while removing the terminal.
Thats me until next week as it is my sons birthday weekend.
Next job will be sort the new power input to the BCM and run all the cables through the bulkhead.
Thanks again Ciclo
Hello reido80, we are progressing positively.👍
Once I have read everything you comment on in your two previous posts:
- The thickness of the wires is specified in all the diagrams, even in the diagrams I made for the T5 automatic lights. Look at them.
- Good luck with that new windshield.
- 1) Maybe you might be interested in installing an RVC (OEM). Adam87 did it on his T5. Look for Adam87 in the forum search.
- 2) It is a good idea, it is what I have always recommended for ALWR. Use a T2 connector to join these wires (not with splices, faults could occur).
This CAN line is called the 'powertrain CAN line'. (old and isolated IC CAN lines)
It is the most important CAN line, there are several CAN lines that fulfill different functions. In each of these CAN lines there are different groups of units, depending on the speed necessary for data transmission and other factors. If the information to be transmitted is 'little', a single wire called LIN is used. (sensors, etc)
They all end up in the GW to manage the information.
- 3) you can run the Low Beam wires directly from the BCM, it is specified in the original diagrams. No problem, BCM will manage these lights. Fuses are not required. (what I proposed is an easy adaptation, so that we understand each other).
You have to add the signal for High Beam as specified. It doesn't matter from where you take the signal from the wires for HB. But you must remember the point of taking for possible diagnoses in the future in case of lamp failures, etc ... It is best to follow the original diagrams.
- 4) No. T73b/3 and T73a/5 :lol: are the signal outputs for DRLs. DRLs activation is because you (or automatic lights) send the input signal to T73b/29 from the new Auto light switch. Run some new wires from the BCM to the headlights.
Note: maybe I didn't quite understand what you meant in your post. :|
- 5) Perfect!👌
Have a good weekend and enjoy your son's birthday.
Shadow109
Drives: Vw t5.1 2013
Post by Shadow109 »
Hello, what is the minimum bcm number needed for auto headlight and rain sensor ?
Hello
7H0937089 D or F for 7L3 (without start/stop)... "old BCM, 2012-2013".
reido80
Post by reido80 »
OK, so I have done the majority of the wiring, and enabled xenon lights in BCM.
Still waiting on 646 relay for auto lights so this is currently missing. Also no RLS or ALWR plugged in.
Only Right hand headlamp wired in so far, The left will be fitted when I refit the bumper.
At the moment I have no DRL led function at all.
High beam works if I pull the stalk to flash but if I push the stalk forward nothing happens.
current fault scan-
3 Faults Found:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 130877 km
                    Date: 2020.08.20
                    Time: 00:05:05
                    Ambient air pressure: 970 mbar
                    Voltage terminal 30: 12.320 V
                    Exh.gas temp.sen 3: 21.9 °C
                    Shut-off timer: last engine shut-off time: 312 s
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 130877 km
                    Date: 2020.08.20
                    Time: 00:05:05
                    EGR Solen.val.: actual value: 100.01 %
                    Throttle valve adapter: actual value: 104.35 %
                    Charge air pressure: actual value: 986.0 hPa
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 130877 km
                    Date: 2020.08.20
                    Time: 00:05:05
                    Charge air pressure: actual value: 977.4 hPa
                    Sensor for charge pressure between turbochargers: raw value: 980.6 hPa
   Revision: 00H43001
   Revision: 00001010
   Coding: 0000000002
2 Faults Found:
13701936 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [Steuergerät für Bordnetz - bitte Fehlerspeicher auslesen]
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 17
                    Mileage: 130877 km
                    Date: 2020.08.20
                    Time: 00:12:48
          U1113 00 [009] - -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 232
                    Mileage: 130877 km
                    Date: 2020.08.20
                    Time: 00:05:02
   Coding: B8B079B80E61241192284E106E6995550080660F60844001320000000000
   Coding: 050000
   Coding: 050000
   Coding: 820000
6 Faults Found:
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 232
                    Mileage: 130877 km
                    Time Indication: 0
                    Date: 2015.01.11
                    Time: 00:17:23
02745 - Bulb for Daytime Running Light; Left
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 232
                    Mileage: 130877 km
                    Time Indication: 0
                    Date: 2015.01.11
                    Time: 00:20:56
02746 - Bulb for Daytime Running Light; Right
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 232
                    Mileage: 130877 km
                    Time Indication: 0
                    Date: 2015.01.11
                    Time: 00:20:56
00978 - Lamp for Low Beam; Left (M29)
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 232
                    Mileage: 130877 km
                    Time Indication: 0
                    Date: 2015.01.11
                    Time: 00:22:37
03906 - Control Circuit for High Beam Relay
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 232
                    Mileage: 130877 km
                    Time Indication: 0
                    Date: 2015.01.11
                    Time: 00:21:49
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
                    Fault Status: 00101000
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 16
                    Mileage: 130877 km
                    Time Indication: 0
                    Date: 2015.01.11
                    Time: 00:21:49
   Coding: 118001
1 Fault Found:
          U1111 00 [009] - -
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 232
                    Mileage: 130877 km
                    Date: 2020.08.20
                    Time: 00:05:03
1 Fault Found:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 130877 km
                    Date: 2020.08.20
                    Time: 00:05:05
   Coding: 160E00
1 Fault Found:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 232
                    Mileage: 130877 km
                    Date: 2020.08.20
                    Time: 00:05:03
   Coding: 0000031
   Revision: B9074001
   Coding: 042300
1 Fault Found:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 232
                    Mileage: 130877 km
                    Time Indication: 0
                    Date: 2015.01.11
                    Time: 00:05:07
   Coding: 0000007
   Serial number:
Address 69: Trailer
Cannot be reached
End----------(Elapsed Time: 02:06, VBatt start/end: 12.4V/12.4V)-----------
Everything is normal and logical, finish the electrical part and I give you your BCM coding for automatic lights, etc. :wink:
Hi reido80.
BCM
New coding
B8B079B80E61241193284E716EEB97554280662F60857841320000020000
RLS (1K0 sensor)
New coding
0230AD
These are your definitive codings for Automatic Lights (+ CH/LH) and Bixenon Headlights.
Therefore, code your BCM and RLS whenever possible with these new codings, ... and until you have no bugs in the BCM we will have to work to fix them. :wink:
