Alloy wheels
Reidul79
Drives: Polo 6R 1.4TDI
Alloy wheels
Post by Reidul79 »
Hello guys,
Just bought a 2015 Polo 1.4 TDI less than a month ago.
It came with 175/70/14 wheels and tires. Wanted to upgrade to alloy wheels 16-17 inches. What setups do you guys suggest?
Re: Alloy wheels
What do you want from a car to be more stable and sporty or comfy?
Reidul79
Re: Alloy wheels
Post by Reidul79 »
Stable and sporty.
Re: Alloy wheels
215/40/17 a tad stiff
215/45/17 - you get grip, and stability with and comfy
For perfect fitment 17x8" ET 35
If you want the tail to rotate more quickly 215/40 fronts , 205/40 back
I would go for 215/45/17 setup ( cheaper tires, grip, sidewall has se thickness if you hit pothole u wont bend the wheel etc. Its a nice balance)
Reidul79
Re: Alloy wheels
Post by Reidul79 »
Thank you!
I’m going to see some options now. 😀
Re: Alloy wheels
amer6R wrote: Mon Oct 05, 2020 8:15 pm 215/40/17 a tad stiff
Did you not mean 17" X 7J as 8J with 215 section tyres will lead to slight stretch offer no rim kerb protection and is not a size recommended by VW so maybe cause problems with insurance.
Re: Alloy wheels
No I mean 215 on 8 inch width wheel. It looks the best and pushes out the wheel to the corners.
7 Inch wheel or 7.5 with 35 doesnt look so great.
Yeah 215/45 isn't factory but its a "standard" rubber size meaning it's a lot cheaper than these faggot sizes like 205/40, 215/40. I think it gives best of all worlds, comfy, stable, grip.
215/40 is factory but it's not so comfy.
If he wants factory buy oem GTI wheels and some 215 40 rubber and go.
