Which engine oil?
hollesk
Drives: 2020 Polo GTI
Which engine oil?
Post by hollesk »
Hi all,
Just wondering which engine oil to buy for my 2020 Polo GTI 2.0 TSI. Engine code is DKZC, i'm not sure if the engine has a particulate filter or not. Any help would be appreciated.
Cheers,
Keith
German_Fartbox
Drives: Polo GTI 2.0 DSG (2020)
Re: Which engine oil?
Post by German_Fartbox »
hollesk wrote: Thu May 13, 2021 10:23 am Hi all,
Cheers,
Keith
Not really answering but why are you filling it yourself? I would just let the dealer do it when its serviced.
Assume it’s for topping up between services, as some engines may use a little oil - sometimes this is only during the first few thousand miles. On previous VW’s I’ve had to add a small quantity at some point during the first year, but no more after that.
hollesk
Post by hollesk »
Spot on yep, just want to have a bottle there for top-up's between services so looking to know which oil to use, manual not clear on that!
ho8882000
Drives: 2019 (AW)
Post by ho8882000 »
If for top ups, it is safer to get the original VW engine oil from the dealer.
But in case you need to drain and change the oil, the following link has the oil specification for Polo (AW) of different engines:
viewtopic.php?f=71&t=75558&p=576488&hil ... il#p576488
ho8882000
Drives: 2019 (AW)
Post by ho8882000 »
To check if your Polo has particulate filter or not, check the following link:
viewtopic.php?f=71&t=73177&p=577929&hil ... il#p577929
hollesk
Post by hollesk »
Cheers!
Just check the dealer didn't put you a 1L bottle in a black zip up case in the spare wheel area. Sometimes they do.
hollesk
Post by hollesk »
Cheers, I wouldn't be so lucky! You get nothing for nothing here in Ireland lol
Harrihealey02
Drives: 2018 SEL
Post by Harrihealey02 »
Use Pemco / Mannol / Fanfaro oil from Autodoc. They are VW 504/507 approved and PAO / Ester based oil for ONLY £20 5L worth! Can't get better than that tbh!
Harrihealey02
Drives: 2018 SEL
Hey, check out PEMCO Engine Oil in the AUTODOC app https://m.autodoc.co.uk/pemco/15769814
German_Fartbox
SRGTD wrote: Thu May 13, 2021 11:06 am Assume it’s for topping up between services, as some engines may use a little oil - sometimes this is only during the first few thousand miles. On previous VW’s I’ve had to add a small quantity at some point during the first year, but no more after that.
Yeah sorry that makes sense.
