Polo 2016 base unit removal
monk2000
Drives: 2016 SE TDI
Post by monk2000 »
Hi all,
Am trying at the moment to remove the mib base unit from the glove box ( located at the bottom, not the top) I managed to get it halfway out but it doesn't come all the way out. am I overseeing something? Please don't tell me I need to unplug the cables before I remove it :shock:
Robbo770
Drives: Polo SEL 1.4 tdi 2014
Re: Polo 2016 base unit removal
Post by Robbo770 »
You will need to drop the whole glove box as the cables are quite short.
I had the whole glovebox at about 6- deg into the foot well to get the cables to allow access to the rear of the unit for disconnection as the clips are all at the bottom face of the unit at the back
ricoghardforth75
Drives: 2016 Polo 1.2 TSI Match
Post by ricoghardforth75 »
Trying to remove the cd unit to insert a after market car play unit between the wiring. Found this video but stil can't feel my way to release either of the two clips and the video doesn't show what the clips look like and what you actually have to do to unclip them. Any one got a close up of the clips so i at least know what I'm having to do blind by feel. https://www.youtube.com/watch?v=Lh0y6-lrcKA
CarbonChaos
Post by CarbonChaos »
The two clips are clearly shown in the video @ 4.35 these are wiring loom clips that slide over a bracket and grip onto it with teeth, by prising them up and away from the bracket you can release the loom the clips have a metal insert to grip onto stuff.
