david burton wrote:
Do you want to change the shocks because the handling has gone to pot, or because you think they will pop?
A bit of both really; bottoms out far too easily and has, I feel, insufficient damping. The former is probably due to the later of course! How far has yours gone down and did you fit your 16v shocks from new? Could just be they are more tired then I was led to believe....(20k old)...hmm, I may try fitting the Spax Golf mk1 top adjustable inserts I have in the front, they should be up to the job.
Clearance wise I can happily live with it as I'm still able to go speed bumps etc and can get up my driveway which is at at least 45 degrees to the road.
A local breakers has shortened mk2 shocks with a receipt for May this year but it was front ended and bent the driver's side one
I could get the rears though
