I'm thinking of getting one of those ODB2 cables and the vag-com software to go on a laptop.
if you ebay it you can get the stuff for about 50 or 60 quid all in.
anybody had any experiences with this stuff?
cheers
anybody bought an odb2 cable with software before?
david burton
careful, I very much doubt the ones on Ebay will include a registered copy of the software.
That means you get cut down functionality, basically all you can do is read fault codes & look at info, you can't make many changes to anything & it wont translate the fault codes for you. You have to find & print a list of what the codes mean.
If you buy the software from the proper place (ross-tech I think they're called) then you are paying the extra to register the software which unlocks the full features. It's not a case of getting a code either as it's dependant on a single computer.
david burton
