anybody bought an odb2 cable with software before?
david burton
Post by david burton »
I'm thinking of getting one of those ODB2 cables and the vag-com software to go on a laptop.
if you ebay it you can get the stuff for about 50 or 60 quid all in.
anybody had any experiences with this stuff?
cheers
hayesey
Post by hayesey »
careful, I very much doubt the ones on Ebay will include a registered copy of the software.
That means you get cut down functionality, basically all you can do is read fault codes & look at info, you can't make many changes to anything & it wont translate the fault codes for you. You have to find & print a list of what the codes mean.
If you buy the software from the proper place (ross-tech I think they're called) then you are paying the extra to register the software which unlocks the full features. It's not a case of getting a code either as it's dependant on a single computer.
david burton
so i could get the cable from ebay and best off buying the software (60 quid i think) from vagcom supplies?
cheers
