cheers richard
ETKA access
genesisGT
ETKA access
Hi, is there any other way to access the ETKA database apart from going into the nearest VW dealer? As a have to make a 20mile trip everytime a want to check something (about 3 times a month). The chaps at vw are quite happy to look up stuff for us, and like talking about G40s and GTs as they used to have a few lying around!!!
(there gone a asked!)
It would just be easyer if it was on-line or on a CD.
cheers richard
cheers richard
Tahrey1043
- Location: Birmingham! Enjoys: The pseudo-G-Smiles provided by a 1.6 Megane Sport valver...
Steve_O
Guessing it will run at 1024x768...
Not a problem for me as i'm running 2560x1024!!TIPS FOR WORKING AT 1024x&768
If your monitor only supports 1024x768 resolution do not dispair! ETKA will still run just fine and you will still be able to exploit its functions, but these tips may help you on your way.
Once in the VW model select screen, the following VW models are accessed by pressing the down arrow on the keyboard followed by 'Enter':
TR [transporter]
TRSY [transporter synchro]
T2 [type 2]
T2SY [type 2 synchro]
T3 [type 3]
VE [vento and jetta]
VESY [vento and jetta synchro]
1200 [beetle]
To zoom to a masked part of an illustration, simply click on the 'Functions' button [upper right hand side of screen], and then activate 'Illustration Zoom'.
To scroll through the parts listing for a particular illustration, simply click on the 'Page Text' button [uppermost on the screen].
To close any window of which you cannot see the 'ESC' button, simply press 'ALT F4' on your keyboard.
To switch between ETKA and your other Windows programs, press the 'Microsoft' button on your keyboard [between 'Ctrl' and 'Alt'] to reveal the Taskbar.
Remember that ETKA is the excuse you always needed for that 19" TFT monitor!!!
amstrange1
- bstardchild
- Moderator
- bstardchild
- Moderator
madmatt
- Moderator
Re: DVD...
can i just inform you guys who want elsa if u have polos mk1 2 3 its pointles having it becouse the old cars aint on it as i found out at work (vw main deeler) but eventual vw thinks they will stick the old stuff on itpete69zx wrote:Watch this space m8, think it will be on DVDmetz wrote:I asked for an original one not a pirate copy![]()
Cheers.
Pete
- bstardchild
- Moderator
Re: DVD...
So I'm Ok with my MKIVmadmatt wrote:can i just inform you guys who want etka if u have polos mk1 2 3 its pointles having it becouse the old cars aint on it as i found out at work (vw main deeler) but eventual vw thinks they will stick the old stuff on it
OK I'm in bandit teritory in the MKIII section
* gets coat and leaves
