anybody elses ash tray get stuck in?
13twelve
Post by 13twelve »
i dont smoke, so i use my ash tray for keys and credit cards at car parks etc.
but the bugger keeps getting stuck in
whats all that about?
Criz
Post by Criz »
Dunno, I removed mine and replaced it with an afrm :P
13twelve
Post by 13twelve »
Criz wrote:Dunno, I removed mine and replaced it with an afrm :P
afrm?
polo_chick
Post by polo_chick »
Yeah I've had real problems with my ashtray! Don't smoke myself but the b/f does ... got stuck and a mate tried to pull it out ... so now it's broke and won't come out at all! :?
Opps!! :roll:
13twelve
Post by 13twelve »
sometimes you really have to pull the ashtray really hard to get it to open
argh!
wrighty
Post by wrighty »
Mine stick too, but its because its full of fag ends. (stressfull job) Helps to empty it once in a while. :lol:
bstardchild
Moderator
Post by bstardchild »
OK - to all those people who have sticky ashtrays
Remove it
Wash it
Dry it
Wipe all the congealed detritus off the runners on the dash centre section
And try some silicone spray on the runners (Back to Black is a good substitute BTW)
Should slide smooth after a small application
Criz
Post by Criz »
afrm?
Air-Fuel-Ratio-Metre
bstardchild
Moderator
Criz wrote:
afrm?
Did you fit it on the existing Lambda sensor or drill a new hole weld a boss on and fit an additional one?
I hope you don't mind me asking because I've used them before for chip development work and on Vauxhalls they play havoc with the ECU if you run them piggy backed to the existing lambda
I had to fit another lambda in the end run a separate power feed to get a true reading and stop the thing screwing up the ECU
I plan to fit one to the polo once I get another ECU to start playing with the maps and if I can piggy back then it will be a result other wise I'll get the welder out again
