i dont smoke, so i use my ash tray for keys and credit cards at car parks etc.
but the bugger keeps getting stuck in
whats all that about?
anybody elses ash tray get stuck in?
polo_chick
- bstardchild
- Moderator
- bstardchild
- Moderator
Did you fit it on the existing Lambda sensor or drill a new hole weld a boss on and fit an additional one?Criz wrote:Air-Fuel-Ratio-Metre13twelve wrote:afrm?Criz wrote:Dunno, I removed mine and replaced it with an afrm
I hope you don't mind me asking because I've used them before for chip development work and on Vauxhalls they play havoc with the ECU if you run them piggy backed to the existing lambda
I had to fit another lambda in the end run a separate power feed to get a true reading and stop the thing screwing up the ECU
I plan to fit one to the polo once I get another ECU to start playing with the maps and if I can piggy back then it will be a result other wise I'll get the welder out again
