Door Locks
sorted
Door Locks
Post by sorted »
Car was broken into - subs , amp and cd player gone
They tried to break the door lock (drivers) without succeed they put the window in. ( Drivers + Back Window)
The lock on the drivers door is shafted - vw want 117.50 to supply and fit !
Thing i want to know is -
Can i use the passenger door lock in the drivers door ? B
Because then i would put a back hand on the passenger door with a blank handle basically - them i would use the passenger handle + lock , on the drivers side - then i would have only one lock to get into the car , that seems securer/safer/cheaper. (If the lock fails i can use the boot to get in)
Thanks Neil.
neilw
Post by neilw »
Sorry to hear abouth the break in.
Should work, there really easy to take out if you wanna try it, just 1 torx screw at the end of the handle at the end bit of the door. Then fit a de-locked handel to the passenger side. or if you have remote central locking de-lock both sides. I got too back handels for VAG parts was less than £40 i think, then you just have to paint them.
niks
Post by niks »
what bastards!!! :x
carmadaaron
Post by carmadaaron »
wtf? all ice gone?
anyway, theres a guide in the DIY section on how to take off door handles and lock etc..
HTH
cheers
cyhliu
Post by cyhliu »
The thieving Bar Stewards!
It's so annoying, why can't they work and save some hard earned cash rather than nick someone elses'?
On a better note, get those de-locked handles, they are simple to fit, even I could fit mine! (and they make a difference and prevents this happening again).
