Mileage on a full tank...
Just wanted to know, i've done a thread like this before, but recently i changed the air filter, and the car is doing a bit more miles to a full tank.
It used to be able to just about do 183ish, now it's doing 200+, i'll definately check the meter tomorow, since it's near the E line on the gauge.
Anyway, this is how it's going to be:-
Car:- 1.4S Auto 5 door
Mileage to full tank/Miles Per Gallon:- 200 (approx.) on full tank
Mine depends greatly on the weather and the type of journeys I'm doing. It can be over 400 but at the moment it is about 290. But if I take some motorway trips at about 75 it goes up to about 350 at this time or year. Its the cold starts when its running rich with a big manifold heater turned on that screws up your economy!
1.4 16V
1.4 16V
Re: Mileage on a full tank...
You must have a heavy foot, or you have wide tyres on or something. Put some more wind in your tyres and you will find your economy will go up.kapur wrote:Just wanted to know, i've done a thread like this before, but recently i changed the air filter, and the car is doing a bit more miles to a full tank.
No, the spec says it should never really be under 40mpg on combined journeys. But if you do short journeys and lots of booting it then it can rapidly go to less than 25.
A tank is about 9Gal plus about another 1.5 gal for neck and all the other bits. so at 45 mpg thats about 405 miles, but say you leave one gal, that should be about 360 on a nice long run.
200 is 25/gal and that is very poor economy.
Concorde does 9 mpg / passenger!
- bstardchild
- Moderator
Not very fast - judging by the ammount of extended wing the last one I flew in needed to get it's lardy arse of the deck - they are quite quick on initial acceleration - winding it up to full chat with the brakes hard on does lead to a fairly impressive burst of acceleration - I do it in autos myself13twelve wrote:but what i wanted to know, and couldnt find out, is how fast a 747 is on take off
VRotate ? About 140 knots? (155mph) Depends on load, pressure, temperature etc etc etc.
Another random fact?
A cheetah can do 0 - 60 in 3.8 seconds and has a maxiumum output of over 45 Horse Power. Thats a standing quarter mile in about 6 seconds less than your GTi. But at the end of it it has to go to sleep for half a day.
- bstardchild
- Moderator
- bstardchild
- Moderator
Winter makes it worse..... MKIV 1.4 8V - sloth - 195/45 15's have just be replaced with 185 14's to see if I can get back above 40mpg!!!nuttinnew wrote:Mk4 1.3 spi standard but for 195/45/15s used 40.69 litres to do 361.9 miles on Saturday, approx. 40.5mpg. Considering I was taking it easy I find that rather poor and think I'll be getting rid of the 195s. On a similar trip driven in a similar way my mk3 Fox did 53mpg
Current tank 210 miles and just over 1/2 full but it drops like a scud after half a tank
