[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 tyre sizes on 14's - UK-POLOS.NET - THE VW Polo Forum
ive just put some 14" bbs wheels on my gt, et38 it says on the rim and they have 185/60 14 tires on, they scrub really bad on the front on the inside of the arch, they are 6.5j x 14h2.
any help would be great or im off to get my 15's back
cheers
james
ps is there any other numbers on them to determine sizes etc?
its lowered by 40, i thought they would go straight on being 38 offset and seeing as i was running 195/45 15's before i didnt think i would have any problems, its more the drivers arch catching than passenger.
On a 14x6 wheel I went for 195/45/14's they look the part (lower profile) and were cheaper than 185/50/14's.
The wheels originally had 175/60/14 and were scrubbing quite bad on the GT with standard suspension. The G40 is lowered at least 40mm if not 60mm (not sure) and there is no problems whatsoever on 195/45/14
The only thing I noticed is that it sits slightly higher on the 195/45/14 than it did on the standard G40 13" alloys (175/60/13) not that you would really notice though, strange as I thought it would have been lower still...
James.
If the original tyres were 165/65/13 then your 195/45/14 tyres will put your speedo out by about 2mph..ie:- speedo says 60mph but your really doing 58..so your safe
lord_sharpy wrote:its lowered by 40, i thought they would go straight on being 38 offset and seeing as i was running 195/45 15's before i didnt think i would have any problems, its more the drivers arch catching than passenger.
Cause your sitting on the drivers side so its proabably lowering the car abit so it snatches more.
I have continental contisport 185 / 50 /14's theyve done over 10000 miles now and are showing little wear..and the grip is fantastic...even in the wet stuff.
yeh the car has sagged over time, does anyone know where i can get some cheap 185/50 14's ive tried mytyres but there quite alot or does anyone have a part worn set?
cheers
james
