F****** welding
Chat about your MKI or MKII Polo (86 and 86F)
polo-vixen
F****** welding
Post by polo-vixen »
I have me coupe, and needs some welding on the drivers wheel arch, just in front of the suspension,
But the polo being the polo, had to have the Petrol tank behond the the wheel arch :twisted: :twisted: :twisted:
So me prob is that it wont pass mot, without welding, and i cant weld with the petrol tank there as it Bye bye coupe :shock: :shock:
So anyone know a good way to drain the petrol, not brake the tank, and if i brake it , how easy i it to fit a new one?
Well thats the essay over!
ste mk1lx
Post by ste mk1lx »
sorry but I don't understand where does it need welding? the sill, the inner arch or the outer arch, depending on where it is it may not have to be welded
polo-vixen
K the inner arch of the car, just in front of the end of the suspension, were it joins the beam, and it more then 5 cm long, and if u poke it , it crumbles, and goes straight though!
i cant explain it any better then that!
ste mk1lx
Post by ste mk1lx »
right according to the mot rules corrosion must not be within 30cm of a suspension mounting point or seatbelt mount, tbh I'd get it welded at a garage and let them worry about the petrol tank as it sound like its near the axle beam mounting
GroovyCarrot
Sponsor
Post by GroovyCarrot »
You'll just have the syphon the petrol out and drop the tank off if you're doing it yourself. I'd second the idea of getting it done professionally though if it's near any kind of structural support.
VF_Marshall
Post by VF_Marshall »
I've done a similar repair to my early Derby. It seems like a Polo weak point. To do the job properly, the tank really should come out (i would budget for a new one, just in case the filler neck separates from the tank on removal) and the rusted steel cut out and relaced with good clean stuff. It's a horrible job to do yourself, you may also need to remove part of the outer sill to get at the rot that will be hidden behind. Good luck with the repairs.
polo-vixen
Seems like this car is costing me more then it worth at the moment,
:evil:
VF_Marshall
Don't get too down heartened by it, get a quote to do the work first. I would guess at around £200 - £250, excluding a new fuel tank. Also, the "other" side might need doing too within a short time, but at least that can be done with the tank in. Don't scrap it just yet...
polo-vixen
I have a quote for the welding its 60 quid and the gargae will basically chnage the tank for nout!
And both side need doing, but it the tank side that is causing the probs!
And a new tank is bout 100quid it looks at the moment!
VF_Marshall
That's a good price, bite their hands off. Well worth getting it all done. If your fuel tank's gotta come out, i would replace it if it's visibly rusty anyway. Save you a lorra lorra trouble in the future.
polo-vixen
well i dont wanna bite there hands off , but yea that is a good price, but that fact that mot, insurance, and tax are al together and the tank is gnna cost a f*****g foturne
VF_Marshall
Found this on the net:
http://www.shopcreator.com/mall/product ... rect/VW21c
New tank for £42.90...
Make sure you get the right one, if your car is a Carburettored version, then the tank i've linked you to is correct, if your cars fuel injected, then you'll need a different tank (on the same site...).
polo-vixen
thanx i have seen, that im just funny about spending alot of money thats all
VF_Marshall
Okay, good luck with it anyway.
mkoprulu
Post by mkoprulu »
polo-vixen, i need to change my tank as well, already got another tank but my last quote was £40 when i paid only beans for the tank (scrappie) so i didn't bother. Can you get a quote for only a tank change next time you are there? And where's the garage located?
Thanks.
