Speedo not working, need help locating the sensor
irishkeet
Re: Speedo not working, need help locating the sensor
Post by irishkeet »
alexperkins wrote:you need to plug it in and loads the instruments group (not engine 01) and check for fault codes as these have their own diagnostics.
Hi
Just done and this is all that comes up??
i guess i can try removing the wiring from the sensor connector and refit in case there is a bad contact, other than that Im stumped
irishkeet :shock:
irishkeet
Post by irishkeet »
Just ordered a new connector for the sensor (part: 357 972 753)
At least this should narrow down what the issue might be.
im 99% sure its not the wiring - it wouldnt just fail like that as VW wiring is very high quality.
On vag com, in instruments, run the diagnostics and see if the speedo diagnostic runs as it has a good self test feature
irishkeet
Post by irishkeet »
Hi Alex
Just been out to the car but in instruments, I dont seem to have a run diagnostics option, below are screen shots of my options...
Options going from Common to Instruments
Entering Instruments from Electronics 1
Options going from Electronics 1 to Instruments
am I missing something in the software options?
using version 409.1
cheers for all your help so far m8
irishkeet
Output tests sorry long day lol
irishkeet
Post by irishkeet »
alexperkins wrote:Output tests sorry long day lol
lol
tried that but told I need the full version of the software :(
ah gay search for the patch on google ;)
irishkeet
Post by irishkeet »
Alex you have a PM.
On a positive note I changed the coolant temp sensor whis is all working
The MOT is due in Jan will they check the speedo, I presume its a fail if its not working?
irishkeet
irishkeet
Post by irishkeet »
Alex you have a PM.
Just ran the Output tests..
all lights and gauges work fine except for the speedo, so as you suspected it must be a clock issue.
From reading the haynes it looks like one big plug that goes into the instrument panel instead of individual wires for each instrument, is this something I can fix or will it need to go to a garage, if so any ideas where, I guess VW will charge a fortune?
thanks again
keet
