just hooked up my jl amp, have a slight problem, the amp doesnt turn off with the head unit or with ignition, connected the remote wire from the amp to the blue and white wire on the head unit.
Any ideas, its a CDA 9812RR btw
cheers
Alpine HU remote wire
I had this exact same problem today while fitting my 9833R.
To solve the problem, you have to cut the BLUE wire on the loom you get with the headunit. Just snip it and tape up both ends.
Then connect your remote cable from the amp to the BLUE/WHITE from the headunit and it will switch on and off fine.
