How do i remove the indicators, they have some muck in the gap between them and the headlights, I wanna take them off so i can give them a good clean. (not the side repeaters)
Can anyone give me some instructions or a walkthrough/guide?
Phill
Removing Indicators
polopowah
- Location: Hertfordshire Drives: Ford Puma 1.7 Enjoys: Mowing grass
lift the bonnet up, you'll see a plug with a hole(it has ridges on it, to lock the indicator in place) get a screwdriver and twist it clockwise until it lines up with the grooves then pull it up, the indicator unit will then come out forwards
crappy pic i just took but should give you some idea
-Ben-
-Ben-
