hi ppl new, im to the site so helo!, prob been asked a thousand times, what transplants are common, what needs to be done how expensive are they, straight swap or not?? was thinking a mkI or mkII golf 1.6 or 1.8 GTI engine, is this possible? how much work is needed??
thanks in advance to any reply
Col.
engine transplants for a mkIII polo
Tahrey1043
It has to be a "short block" engine, unless you're prepared to make yourself a custom bonnet with a big ass bulge in it - and custom mounts. Which unfortunately rules out a lot of the larger units. I think I've heard one story of someone getting a 1.6 in there, but it was either a hybrid setup, or some short stroke oversquare variant. Mostly a 1.4 is your lot in a mk3, from as much as i've seen thru ukp anyway.
However a 1.4 GT or G40 would be a satisfying drive. The car's so lightweight after all that you can give some people a surprise in a 1.0 (and the regular GT/G40s are no slouches), so those would be very sparky.
Karl_CLCoupe
Karl_CLCoupe
hardhitter
- Moderator
Krupa
I'll second that, don't be fooled by the fact that you can get a G40 engine for under a grand. To do a G40 conversion 100% properly it's best to get all sorts of things renewed, like the charger (£500 if you want to go full blend, which you will!) fuel pumps (over £200 from VW, and at least £120 from GSF) filters and whatever gaskets are old and cronky. Things like that add up!
Including fitting and minus what I hope to get for my GT engine taken off my G40 conversion is costing me... well... a fair amount more than a grand.
