Blue Temp sender
Blue Temp sender
I changed the thermostat housing yesterday as it had a leak, i changed all the seals and the thermostat too but didn't change the senders as they were working fine..the car idles at just below the 1000 mark fine and when you unplug the blue temp sender the idle rises to 1000rpm....its hardly noticible though..does this mean the sender is now broken because of my meddling?
Karl_CLCoupe
Tahrey1043
yea it idles about 900rpm but when i unplug the blue temp sender when the engine is warm the idle only goes upto 1k (people said 1300rpm)
when i plug it back in it doesn't drop straight away but takes about 5 seconds to gradually go back down...is this right?
just since i messed around with it the blue sensor wobbles about a bit in its slot..no leaks though. (those clips were a right pain to get back in and i think the hammer may have something to do with my problems)
