Hi, ive done a quick search but cant find what im after.
Ive bought a VW single CD player of ebay to hook up to my Mother in laws 1 year old Polo. I need to remove the coin tray shelf thingy and pop in the CD player, how do i do this i cant find an Install guide?
Ta
Joe
Fitting a VW CD player?
joebickley
carmadaaron
joebickley
carmadaaron
yes better to take the HU out, unless you have tiny handsjoebickley wrote:Nice one i thought it might be the case, i just have to drive a fair way over the In Laws which is a technology dead zone so if i get stuck i got no hope of popping on the net for help!
So i do have to slide the main HU out as well, not way i can get the cable in from the back?
Did you get the spacer with the cd player? Here's how I did mine:
Hope this helps.
- Pulled the bottom cubby box out
- Slide the headunit out
- Insert the spacer
- Slide in the cd player in the bottom feeding the wires round the back and through the top.
- With the bottom cd player in position plug it into the headunit
- Make sure there is room for the wires in the back and slide the headunit into place. This should* go straight in.
Hope this helps.
