upgrade vw gamma head unit!
keepitreal53
You can get a plug and play lead from Halfords, sits between the car wiring and the radio wiring, to make the car wiring standard ISO, so that you should have no probs
May have to swap the power wires, but the lead you get should allow this. No cutting of wires needed at all
You might also need an FM booster device, as the OEM VW radio had this built in, when you put a 3rd party headunit in, you will find reception may be poor, to overcome this, you can fit an inline FM booster device at the same time
Hope helps
Hope helps
alpine head unit
hi
just a thought is your alpine fairly new, if so have you installed it before?
if it has a inbuilt amp, 4x 40-50w you may need to take a direct feed from the battery and not from iso connector,as this has caught me out before if in doubt read the manual it should help
alpine head unit
just checked my unit, yellow wire with fuse must go directly to car battery but dont forget to add another fuse close to the battery
anymore info please ask.....
Re: upgrade vw gamma head unit!
Funny isn't it, the S in ISO means STANDARD yet VW use a different STANDARD to everyone else?!keepitreal53 wrote:tryed to install an alpine head unit ,but it wont power up,heard the i.s.o leads on the gti polo are different,and i need an adapter for a non vw upgrade? is this true ? and where can i obtain one,ne help pls
alpine head unit
just install alpine head unit,changer and kicker amp plus 2x12 subs, only problem that i found was the switched live had to be changed so that i didnt have to turn it off manually, ran 4gauge cable from battery to fused distrubution block in boot then reduced down to 8gauge to split off to kicker amp and smaller alpine amp for front diamond audio m5 components,which i dont think i'll fit as standard sound stage is ok,they are now powered by internal 4x60w from alpine h/unit
repeat after me
i do not need 6x9s if i do hit me with some 4x2
repeat after me
