Can you remove the standard twist dials etc and replace it with a climatronic display or are the two systems different in wirig etc?
Climatronic
I once considered this too - but its near impossible and mega bucks, lots to change over and parts to add in, cost of adding makes it not worthwhile and the time it takes too etc....
I think the standard control works with steel wires? climatronic system is all electronically controlled, so temp sensors to add, switches, the loom etc...... nooo
