rear wiper fault
Neil
rear wiper fault
Post by Neil »
My rear wiper on my 1989 polo c has just died a slow death, ie. it actually slowed down to a very slow wipe and then a couple of days later just quit. There is still a clicking noise from what I assume must be the relay or something from under the glovebox area.
Anyone got any ideas on what is up, also the rear demister has never worked since I got it but then the car only cost me £50.00 and it's amazing.
I just fitted some ranger roof rails that I got from a scrappie for £5.00 and it's the ultimate utility vehicle. Nervous moments however before drilling four 1" diameter holes in the roof though!
mk2matt
Post by mk2matt »
check earth and live matey
you have choice of fixin or removing wiper too
Gizmo
Post by Gizmo »
I have the same fault on mine except it's never worked :roll:
Also the intermitent wipe don't work unless you put pressure on the stalk.
Faulty wiper stalk? or just contacts need clean maybe? :?:
mk2matt
Post by mk2matt »
thats the stalk, bad connection
meeky
Post by meeky »
i have that problem aswell
i used the wiper 1day n it was stuck in middle of the window and hasnt worked since.
Gizmo
Post by Gizmo »
LOL
Must be catching!
Worn out wiper syndrome. :lol:
meeky
Post by meeky »
i'll be checkin on weekend hopefully
either fuse gone im hoping
or motor scrappies that'll be
fingers crossed its simple
polock
Post by polock »
Open the boot lid and on the top left hand side there's a rubber boot where the wires pass into the tailgate for the wiper motor and demister ciruit etc.
When my demister didnt work it turned out that the constant opening & closing of the boot had taken its toll on the wiring and the plastic insulation to some of the wires had perished, split and come away completely and on the other wires it was slightly more extreme as the wires had just completely snapped :o
i replaced the damage section of wiring and left plenty inside the tailgate for movement etc. Now all is well.
NB. inside the car the wires pass down the rear corner pillar into the boot where they can be accessed though the hole used to get at the rear light cluster.
Good luck :)
