Dead Battery
henry01
Dead Battery
Post by henry01 »
i went to start my car last night and it did nothing, i dont think i left anything on and the only thing on was the wipers. i know this prob didnt cause the battery problem but i just thort i would ask if that would have caused it? i prob just stupidly left the door slightly open or something
do i need to buy a new battery, it seems to be working fine now as i left it running for ages and went for a long drive??
ukmic
Post by ukmic »
The windscreen wipers wont work unless you have the ignition on, and no I have had my light left on all night by accident and the battery was not dead when I got too it.
AKs_SlickPolo
Post by AKs_SlickPolo »
leaving the rear window heater switch on is common to run the battery down. I probably once pressed my hazard light switch to flash to someone behind, but unknowningly also pressed the window heater switch and forgot it. Maybe u did the same?? :lol:
henry01
Post by henry01 »
well my heater was on so it must have been that. but i think its normally on.
how strange, well its sees to be working fine now
thanks
skyline.99
Post by skyline.99 »
When the car is off it should be alright cos its disconnected thru the ignition, and when the engines on it should b alright if ur alternators ok
DScape
Post by DScape »
My battery was dead the other day, so I had a new one stuck in...defo worth it for the winter, think the cold weather killed the remaining cells of my old battery. I didn't even have anything on, it just was totally dead.
Also, you leave your rear window heater on......until its clear! :lol:
DScape
Post by DScape »
CymruPolo wrote:
DScape wrote:My battery was dead the other day, so I had a new one stuck in...defo worth it for the winter, think the cold weather killed the remaining cells of my old battery. I didn't even have anything on, it just was totally dead.
yeah I know :lol: . . but I forget to switch it off sometimes.
Yup Im in that club too, should have the "you've left your lights on" sound when you switch the engine off! :D
AKs_SlickPolo
No, it does still somehow remain powered, eventhough it is not clearing the rear window. Plus if u have elec mirrors, that switch does the heated door mirror function too i think, so it uses more power there!
As for how long it takes, i dont know, but it should take longer than a few hours id say :?
I try and avoid using it completely, only when really neccessary :lol:
henry01
Post by henry01 »
yeah i got a new battery as well, seeing as its so dam cold i thought it would be for the best.
i always leave my heater on and its never done it before. but just to be on the safe side i wont be leaving it on again :D
