CD Changer Help
nothin2lose
CD Changer Help
Hello, just bought a standard VW 6 disc cd changer from ebay and I need to connect it to my standard vw headunit, but i am unsure of what I will need to do so? I was told i need a cd changer lead but im sure i will need more than just this to set it up. anyone know wat else i will need?
nothin2lose
you never said in your original postnothin2lose wrote:well i already have a single cd player in the dash so it will have to go in the boot.
anyway, you need the cd changer lead, it will bring the power needed and connections needed into the boot. one end of the cable will plug into the cd changer and the other end will plug into the spare plug on the back of your current dash single slot cd player
then you can choose between the two using the chooser button on the single slot cd player
nothin2lose
nothin2lose
nothin2lose wrote:went to vw yestarday and they couldnt supply the lead, will i be able to source a lead from a audio specialist shop?
They must be looking at the wrong item, they can defo get you the boot cd changer lead, part number starts with 1J0 I think, if no stock, should be able to order it in, else will have to check ebay I guess
nothin2lose
nothin2lose
i checked with the dealer, basically he said yeah, took my money and said it was on order, then when i double checked with him to make sure it was the right lead he says "Ohhhh im glad you told me that because i thought you just wanted to connect a single cd player with your headunit",. Then when i asked him if he had the lead for the changer he said "ohhh well we dont sell the lead seperatly we only sell the kit which costs £65exc VAT". I was like Thank You Very MUch and go f**k yourself, considerin i just paid £30 for a tiny piece of mirror.
