PLEASE HELP: NO IGNITION POWER TO HEADUNIT
Discuss In Car Entertainment
HGA05
Post by HGA05 »
Just had some coilovers fitted today and when i picked it up i turned the kwy and the CD player came on. It turned off for about 30 seconds and hasn't worked since. I got an multimeter onto the red and yellow leads and one reads 12.4 volts always and the other 0 even when i turn the ignition on. I connect both to the 12.4 lead and it worked for a minute until the fuse blew. Can anyone help me, i have no clue why the ignition cable suddenly has no power.
tupac2makaveli71
Post by tupac2makaveli71 »
no idea mate? take it back to the place where they fitted the coilies and blame them...that shouldnt happen, they might have cut a wire somewhere although thats unlikely...and also your fuse shouldnt blow when you bridge the live to ignition so thats another problem
HGA05
Post by HGA05 »
For now i have added a wire from somewhere else that only has power when the key is turned but i still want the original one to work. Now that it turns on though, the cd changer is not recognised when i click the source button. Any ideas?
