Just come across a small problem with my window switch.. the passenger window closes but doesnt open from the drivers side.
I know its not the window motor because i changed it with the drivers side window switch and works fine.
Does anybody know where i can get one switch for the drivers side?... or will i need to buy the hole unit?
Also if anyone has bought theses from the dealers how mcuh were they.
vagparts, GSF somewhere like that The switch just pops out, altho you may have to have the door card off to change it (i think you can do it without tho )
yes pops out - take whole surround out and drivers switch pops out backwards....... i have swapped the plugs on mine so drives wires in passenger switch...............unlucky passengers lol.
Zero-Tolerance wrote:yup same here!! where can i get my hands on the switch and how the hell would i change it?
thanks, Alex.
Its real easy to take the switch housing out, even easy to take the actual passengers switch out its is just cliped in.
to take it out you have to get something flat and get it under the housing (top side) and pull up.
Just wondering if i can but jus the switch from VW retail (Dealers)
