Dump Valve Lifting Pressure
- KennyPOLO_Gti
Hi there, gonna be fitting a Dump Valve off a SEAT Leon 1.8T 180BHP to my car tonight. You are able to adjust the tension of the spring to lift at different pressures, the spring has not been adjusted at all, not sure if i will need to adjust for my car and what damage it will do if any if its at a different lifting pressure? Suppose if it is set too high it would over pressure the system (Turbo)
- KennyPOLO_Gti
