1st Service
- KennyPOLO_Gti
1st Service
Can anyone tell me how much I will have to pay for my 1st service on my Polo????
- KennyPOLO_Gti
Nah, VW wouldn't put it out on long life servicing if the car couldn't take it.
I've done 10k since January, all sorts of driving, and a track day, and it hasn't used a drop of oil
I've no worries about it at all.
Slightly off topic, but does anyone know how it is that you get the car to tell you when it thinks the service is due? I've seen people mention it, but can't find the info!
kc
- Drives: an imaginary one... for now
Ross you need to check your handbook for the chassis no and ring your local vw to let them tell you wether they set your car up on time and distance or longlife!!RossG wrote:Nah, VW wouldn't put it out on long life servicing if the car couldn't take it.
I've done 10k since January, all sorts of driving, and a track day, and it hasn't used a drop of oil![]()
mine was on longlife when it first came out (21k miles) but when i first changed oil at 7k the used oil was so thin!
i change every 5k now or so... on healthy good decent oil!
costco rocks! castrol edge 10w/40 for 16quid! woop woop!
0h dear, your gti should run on 0w30 fully synthetic weather it be longlife or not
the oil your using is much too thick and may not be providing adequate lubrication or protection
so in effect you could be doing more damage than good
all the 1.8t engines even from as early as the launch in the a4 in 1997 have used such a thin f/s based oil for its extra quick and easy heating properties for the engines long term protection
if i were you kc, id be considering changing back asap
