[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 after market side skirts help - UK-POLOS.NET - THE VW Polo Forum
has anyone fitted reiger side skirts to there gti and if so what parts are included in the fitting kit and how do they attach to the sills. the reason for asking is my sills are damaged and it is cheaper and easier to fit skirts than get the sills replaced.
How complicated is it removing the sills then? Mine are not in the best shape as the previous owner must have rested the jack on them and I would like to get them fixed up or replaced altogether.
The sills are part of the car...they form quite an important structural element of the vehicle...DO NOT remove them!
If they are in a bad way you may be able to get a new sill and have it welded/bonded to the car...but chances are you will just have to fill and holes and live with it...
There is a few dents on the sideskirts so they are not totally in a bad way but I would prefer them to be straight. Replacing the sills sounds like a big job.
i dont want to remove the sills as it is a major job i am looking at getting a set of side skirts to go over the top but need to know if anyone has bought the proper abs ones and fitted them with the fitting kit provided.
