Need a bit help on this one folks for my older polo
My left hand tell tale is not working and it failed its mot, i took the clocks out and had a look to see if it is possible to change the bulb, but after stripping down the dash only to find its a small light soldered on a circuit bored. can this be replaced?
If i was to replace the clocks from a polo at the scrapyard would the mileage stilll be stored
Is the mileage store on the clocks or the ecu
JarnoVWPolo6N
- bstardchild
- Moderator
